EVO 9 2.4L 6466 GSC R2 Cams E85 28psi
Old Mar 2, 2015 | 10:52 PM
  #46
tscompusa's Avatar
Originally Posted by Booztd3
I have a similar build but on a 10:5 2.4lr 6266 hoping for low tens full spec car . seeing these videos make it seem a lot harder lol
As long as the power is there, and you have a healthy clutch, transmission, and you can shift quick there is no problem getting these cars in the 10's. For the average person it takes about 550-570whp (dynojet vd) to do it comfortably with stock gearing on a 5 spd. (132-135 traps with mid 10's.)
Originally Posted by Howulikemyevo
I have a similar setup like yours.
I know it's been awhile but I was wondering if you have any issue with your car now after 2-3 years?
I did some research of the history of the car to answer your question;
It had a oil pump issue and then a timing belt issue which made the valves touch the pistons. This car had some abnormal mechanical issues that shouldn't have never took place. I wouldn't use this car as your example to scare you away from the platform.
tscompusa
Dec 31, 2019 04:39 AM
tscompusa
Oct 10, 2018 12:43 PM
tscompusa
May 6, 2016 03:47 PM
tscompusa
Oct 17, 2015 12:03 PM
tscompusa
Aug 20, 2015 03:58 AM
