EVO 9 2.4L 6466 GSC R2 Cams E85 28psi
Old May 19, 2013 | 12:15 PM
  #31
01sporty's Avatar
nah just pull the trans. you dont even have to take the clutch or any of that stuff out the hardest part is pulling the trans the bearing replacement will take you like 30 minutes
Old May 19, 2013 | 03:56 PM
  #32
Boost_Inspired's Avatar
My single 416 not rewired ran out of steam around the same power so I had to add in another 255 and hard wire it so now I won't have any fueling issues for a bit. Good results though and times for that high elevation. Would be a mid 10 second car easy down here in the great state of Texas.
Old May 20, 2013 | 06:12 AM
  #33
MaxStreets's Avatar
that sucks hope u get ur trans fixed soon.nice car.good numbers.
Old May 20, 2013 | 04:44 PM
  #34
JohnBradley's Avatar
Nice results guys. 588whp is dead nuts for the weight and trap speed.
congrats
Aaron
Old May 22, 2013 | 04:14 PM
  #35
tscompusa's Avatar
Thanks Aaron. seems like that mivec gear mod works pretty damn good. that spool is really quick. I just picked up some R2's for my evo also. you guys did a great job helping GSC make those they kick ***!
Old May 23, 2013 | 11:52 AM
  #36
el.guerrero's Avatar
are r2 only good for 2.4 or also on a 2.0l can provide better spool and top like s3?
Old May 23, 2013 | 05:09 PM
  #37
Broham's Avatar
CT9,
Thanks for the explanation. There is no way you'd only get 11s with that much to the wheels. I assumed traction was ***, track prep *** and you might have missed a gear. And sure enough that was it. Don't you feel you can go 10's with better track prep and tires?
Old May 23, 2013 | 05:27 PM
  #38
tscompusa's Avatar
Originally Posted by Broham
CT9,
if you look at the time slip you can see its capable of a 10 sec pass with a better 60ft. his tcase is shot i think, so he has to get that fixed now.
also, when talking power, you should refer to mph more so than ET, because ET can vary based on a lot of factors. so can mph though. a missed shift can shave 3-4mph away fairly easy if the car doesn't have enough power to gain it back.
however always go by mph when trying to figure out a vehicle's power level, because too many things can alter the ET performance. but you are correct, it should go 10's with a clean pass.
Old May 23, 2013 | 05:35 PM
  #39
tscompusa's Avatar
R2 would be better on a 2.0L then s3 i think. if you're after all low end and response you should stick with a S1. if you have a midrange turbo like a fp black on a 2.0 and want more top end but not much spool loss you want S2. If you don't mind loss downlow for gains uptop then you can go to a S3 or R2.
I don't know 100% what the R2 does on the evo 8. looking at lift only its bigger then a S3 cam. 12/12mm on both cams.
R2 was designed based on 2.2-2.4 though. but im sure it will shine if you throw it in a 2.0L also since the S3 does also. it really comes down to what you are trying to do with your powerband and what you can sacrifice.
I am running R2's with my 2.2 this time around.
Old Jun 27, 2013 | 04:41 PM
  #40
CT9Asphixyation's Avatar
Quick update: Transfer case will be back in the car next tuesday. Next races are July 12th. I think if I drop tire pressure and get my 2 step dialed in I can run 10s on all seasons. Next step after that is to buy some M&Hs. I'll keep you guys posted.
Old Jun 28, 2013 | 02:24 AM
  #41
tscompusa's Avatar
nice! i got your email i will respond shortly. been working very hard to get everyone solid tunes.
Old Feb 6, 2014 | 03:28 PM
  #42
Howulikemyevo's Avatar
Hi. I just finish my 2.4l built too. But i was wondering if u like the r2 better than the s3 for the 2.4L?
Some say the R2 are made better for the bigger 2.4 than the 2.0.
Old Feb 11, 2014 | 11:44 AM
  #43
tscompusa's Avatar
Personally I run the S3 in my 2.4. I have a set of R2 in my garage also. I never ran the R2 yet so i cant say. They both perform very well though.
Old Feb 11, 2014 | 04:32 PM
  #44
Booztd3's Avatar
I have a similar build but on a 10:5 2.4lr 6266 hoping for low tens full spec car . seeing these videos make it seem a lot harder lol
Old Mar 1, 2015 | 04:29 PM
  #45
I have a similar setup like yours.
I know it's been awhile but I was wondering if you have any issue with your car now after 2-3 years?
