Switched to E85 and only Made an Extra 16WHP
#136
Guest
#137
Guest
#138
When I switched to the 2.2 I made 641@30psi and the 2.4 made 650whp at 29.4psi. With a good twin scroll housing (or even TiAL V-band) it seems like I can push it further than the normal ballistic housing. If this were the case I would think that adding some more boost and timing may have seen 660-670 (DJ) which is where Dave has gotten his I believe after the 13-15% difference from his Mustang to our Dynojet.
#140
Can someone show where 44 lbs/min comes from? I get 36 - 39 lbs/min
I'm not sure where 44 lbs/min for the stock 16G comes from. If MHI rate the turbo at 512 CFM (although at what PSI I don't know), and dry air has a density of ~13.08 cubic feet/pound, to get lbs/min from CFM is 512/13.08=39.14 lbs/min. Even in a ideal scenario of dry air at 0*C which has a density of 12.42 cubic feet/pound, that only puts it at 41.22 lbs/min.
Or if I do it this way: P(psia) x V(cu.ft./min) x 29 divided by (10.73 x T(deg R)) at 65*F, when P(psia)=13.949
then I get 36.76 lbs/min.
#141
I think your problem lies elsewhere. I have been following this thread, but haven't read every post as it's gotten pretty large.
I'd like to see the torque curve. Can you post up a log? I know you said your tuner tried to get more with an agressive tune and it didn't give anything. Is it knocking at all?
#142
A compressor map typically rates the turbo at a PR of 2.0. Also, the compressor in the Evo is the TD05HR-16g6. It has been posted several times in this forum, including by myself with some overlays of maxed runs, etc.
The 2.0 PR rating is 580 CFM. Looking at the compressor map, maxed out it can move over 600CFM at 65% efficiency.
#146
Guest
It's not fixed yet but I believe my Turbo is toast. I ran seafoam through it and turbo was smoking like crazy meaning it has various leaks, especially around the Vband area and even seat foam liquid came out through there. The rebuild kit does not fix it because there is no seal or so in the center cartridge that can be replaced via a rebuild kit.
AWD Motorsports
92
Jul 6, 2016 10:44 PM
Randal
15
Aug 30, 2013 08:39 AM
