Evo 8.9 RMC 2.2 FP red
Old Apr 11, 2023 | 10:25 PM
  #31
Steveevo9's Avatar
It's all she would make. Next dyno graph posted in a month or so will be a Garrett G30-770 on an Artec manifold.
Hi Sean,
Have you had any experience with the Artec exhaust manifold for the stock frame turbos in your shop?
I look forward to hearing about your new turbo, best of luck mate.
Old Apr 12, 2023 | 07:02 AM
  #32
LetsGetThisDone's Avatar
Originally Posted by Steveevo9
Hi Sean,
On the X they're great. Spool same as stock (unlike the other cast stainless piece available) and they also make more power. We see about 15-20whp more with an 18k on E85.
Haven't done an 8/9 one yet.
Old Apr 12, 2023 | 11:10 AM
  #33
Steveevo9's Avatar
I’m assuming the 15-20whp is from the Artec manifold alone, on the X with 18k on E85? We could take this to pm if you require it.
Thanks Sean I appreciate your time.
Old Apr 12, 2023 | 03:14 PM
  #34
On the X, yes. We usually see about 460-470whp on E85 with an 18k. The Artec manifold let's it push to around 480-490ish. With stock sealed motor, including stock cams.
Old Apr 12, 2023 | 06:33 PM
  #35
Steveevo9's Avatar
What gains are through the midrange Sean & how is the torque? The MHI 18K seems like a great street turbo, are they similar in power & torque to the FP Green HTA that flowed 54lb/min (not the lastest HTZ)?
What benefits do you see with your new turbo using the Artec over a tubular exhaust manifold?
Thanks for sharing your knowledge as you always do, a lot of us never knew you ran your own shop, well done.
Old Apr 12, 2023 | 07:24 PM
  #36
The 18k is made by Mitsubishi so I didn't get updated aero.
We don't do tube manifolds on stock frame X's so I don't have data there. But it looses nothing vs a stock manifold. And it also doesn't crack like a stock manifold, or like a tubular manifold eventually will.
The gains are everywhere. Basically it lets us run more boost. So it picks up across the rpm where we're not limited by stock rods.
Old Jul 31, 2024 | 01:32 AM
  #37
AlexEvo26's Avatar
Any news ? Would be glad to see FP red vs G30-770 on your setup 😎
Old Jul 31, 2024 | 01:46 PM
  #38
The G30 spooled a smidge later on the dyno. Wasn’t too noticeable on the street. And easily made about 70whp more, with much better transient response. This was 30psi on E85. It was all the boost the turbo would make. Have have them on 4 2.2L build now, this the number they all make, at same/similar boost and timing. Pretty much max for the turbo.
overall a great upgrade.
Old Jul 31, 2024 | 02:12 PM
  #39
AlexEvo26's Avatar
Thanks a lot for the reply. Bet you’ ll recommend this stuff with v band manifold rather than FP red with twin scroll mani for this kind of power ? (600 whp range)
Seems to be hard to find something with MHI housing (twin scroll), I’ve seen those G25-660 but I bet the turbine would be too restrictive, they flow a bit less than a red according to comp maps
Old Jul 31, 2024 | 09:36 PM
  #40
The only use for a small stock frame turbo is autocross, but you also don't need 600whp for that. Beyond that, vband takes the cake.
Old Aug 1, 2024 | 04:43 AM
  #41
AlexEvo26's Avatar
Clear. Artec offers VB mani so I’ll go this way
Old Sep 15, 2025 | 08:14 AM
  #42
evo4nr's Avatar
Great looking results , wondered if a G35-900(or now 990) with a 0.83 housing would be similar response with +50hp
silthos
200
Jan 25, 2020 04:28 PM
palmerblock
Evo X Dyno Results
36
Oct 27, 2009 10:53 AM
TalonFiero
Jul 13, 2009 10:53 AM
Kevin Knight
12
Jun 19, 2009 06:56 AM
Johnny Fargas
Aug 24, 2008 07:29 AM
