Post exact weights of weight reduction you have done!
Old Feb 15, 2012 | 08:54 PM
  #976
B.J.@ToxicFab's Avatar
Originally Posted by evodan2004
yea i forgot about that.
I see you really don't pay attention to me when we have heart to heart weight reduction conversations.......cool........
Old Feb 15, 2012 | 08:56 PM
  #977
EvoDan2004's Avatar
HAHAHAHAH LMFAO.
im sorry. i will try to pay attention more when you speak.
Old Feb 15, 2012 | 10:21 PM
  #978
EvoDan2004's Avatar
does anyone know the weight of the Nitto 555R DR tires in 247/45/17????????? i used to know but i can not find my notes where i had this on paper. i also thought i posted this info a while ago and i just spent 2 hours back tracking many of my posts. i can not find the weight.
i MUST know.
Old Feb 16, 2012 | 05:06 AM
  #979
HAHAHAHAH LMFAO.
You better...
Old Feb 16, 2012 | 03:06 PM
  #980
EGbeater's Avatar
Just save your pennies and buy a BR front cross member. drops more weight.
or you need it for the jack point.
Don't have access to a lift all the time...So if I am at home, in my tiny 1 car garage, I use it as a jack point...
I actually run a Buschur front cross member myself now, evodan is right; it does save more weight.
I have a tiny two-car garage myself, but there are plenty of places under the front of the car to use as jacking points other than the OEM cross member.
NOTE: Don't let any dyno operator strap the front end of your car down by hooking into the lightweight Buschur cross member's tow loop, from the sides... it will bend! You can get around this problem by running the tiedown straps up and over the Buschur bar, behind where it bolts to the bumper beam with the two front bolts.
Old Feb 16, 2012 | 04:17 PM
  #981
David Buschur's Avatar
Yes, absolutely, I'd think a dyno operator would need his head examined to strap a car down by that loop! I've seen operators tie them down by the rear hook under the spare tire too!
We run an axle strap over the bar between the mount and radiator, two of them, when we strap the cars down. I also never jack my car up by the front, I jack from the jack points on the sides.
Old Feb 16, 2012 | 04:38 PM
  #982
I would jack from the jack points on the sides but my current, 1 car, tiny *** garage, has so little room on the sides its pretty much impossible to do that...
I have plenty of room in the front of the car & obviously the back when the door is open...
Old Feb 17, 2012 | 09:33 PM
  #983
EvoDan2004's Avatar
Originally Posted by Fairclough
Here are some pics of the install.
i got this bracket today. the quality is outstanding. for anyone at this level of weight reduction i highly recommend this part.
Old Feb 17, 2012 | 11:04 PM
  #984
EvoDan2004's Avatar
here are some better pics.
Old Feb 17, 2012 | 11:05 PM
  #985
Nice, bracket looks good! I'll try & head up your way Sunday, if your around, to grab mine...
Old Feb 17, 2012 | 11:07 PM
  #986
EvoDan2004's Avatar
no problem. i should be local somewhere.
Old Feb 19, 2012 | 03:28 PM
  #987
Dynotech Tuning's Avatar
I have some serious weight reduction going on this spring as well. Great thread guys. The wiring harness has just begun...
-Jamie
Old Feb 20, 2012 | 01:41 AM
  #988
EvoDan2004's Avatar
I can't sleep.
Does anyone know the weight difference from the rs non hid non adjustable low beam vs the gar hid with adjustable head light housings?
Old Feb 20, 2012 | 07:04 PM
  #989
StreetThisEvo's Avatar
I can't sleep.
Ahhh...I just had my headlights out (non HID gsr). I could have weighed them for you. Maybe Friday if you remind me I can pull it back out to weigh it for you.
I removed my aftermarket HID ballasts (ebay specials) and am going back to normal non HID 9006 bulbs. Saved 2.0 lbs
Old Feb 20, 2012 | 08:09 PM
  #990
03whitegsr's Avatar
GSR HIDs w/height adjustment = 8.4lbs each
