Name this wire!!!!
Old Feb 10, 2007 | 03:17 PM
Ultimate CC's Avatar
ground wire...
Old Feb 10, 2007 | 03:26 PM
4g63girl's Avatar
ground wire for HID's
Emery
Old Mar 4, 2007 | 03:08 AM
alexlewand's Avatar
Wow somebody said it's power wire wow congratulations and good luck. It's ground like hell.
Old Mar 12, 2007 | 03:34 PM
MyEvolution0505's Avatar
i just did my lights same ones and it is just attatched to the light. i dont think its possible for any kind of power to run through it. it is just a ground and i didnt attatch it to anything just clipped it inside so it wouldnt move and they were just fine!!
Old Sep 27, 2007 | 02:38 AM
Kirbyryu's Avatar
Originally Posted by rice_rocket88
Are you joking me... Power?!?!?
That is a Braided strap, ie.. LIVE WIRE if there is any current on it.. you'll melt down the entire car. It MUST be a grounding strap or a negative ground wire.
I'd help you out by looking at my friend's Evo7, but it's too damned cold outside to pull apart his housing to check.
Can you just look into the housing to check where it goes to seeing as it's not installed yet? If it is just bolted into the headlight housing, then it's probably just overkill. If it's part of the light bulb circuit, then you need to figure out if it fits the HID housings. I know the Evo7 didn't come with the HID stock, don't know about the JDM versions.
Thank you, some people. I have been a mechanic for way more years than I want to say (ok i'll say - 20 + years and learning more every day) A bare braided wire is a ground no matter if it is on a car, truck, semi, or heavy equipment. For those people that think they know get some classes and learn before you give advice and sometimes the end result if the person follows could damage or god forbid if fuel or electrical burn someones car up.
Old Sep 27, 2007 | 05:46 AM
BURNALL_4's Avatar
Originally Posted by dogfacker
ground wire
+1
sikrsix
23
Jan 11, 2011 03:54 PM
sikrsix
Jun 5, 2008 06:59 PM
sikrsix
21
Jul 25, 2007 01:15 PM
sikrsix
May 31, 2007 05:10 PM
sikrsix
Oct 10, 2006 08:32 PM
