When i hit corners, my radio=static!
Old Apr 13, 2007 | 07:03 PM
RalliArtEvoVIII's Avatar
as stated, its weird. it does it with CDs, or when its on the FM/AM..
and even when i hit corners theyre not that fast, its just enough to slightly shift the weight and its static throughout the corner...coudl this be caused by the HKS DLI2 by the way because thats the only aftermarket item im running that would affect any electric currents
Old Apr 13, 2007 | 08:07 PM
Mr2fine's Avatar
very simple, one of the wires connecting to your stereo is loose. most likely its the harness check this if you changed an aftermarket stereo. also check the fuse where the wire is connected to the stereo, check for loose connections
Old Apr 13, 2007 | 09:44 PM
boostless's Avatar
Is it an aftermarket stereo or speakers? Grounding is important
Old Apr 13, 2007 | 11:20 PM
no...ITS STOCK!!
Old Apr 14, 2007 | 05:58 AM
dubbleugly01's Avatar
I would check for wiring issues around the radio or speakers first. The DLI is most likely not the problem.
Old Apr 14, 2007 | 07:21 AM
hmm ok ill check fuses first thing..odd how this could have happened on a stock stereo system
Old Apr 14, 2007 | 07:32 AM
mohseen87's Avatar
i have the stock Cd player and its kinda ****ed up... not sure if its the CDs i use to burn it (they work fine in other cars) but on every CD new or old, around track 6-9 the songs dont play, they get all scrathy
Old Apr 14, 2007 | 07:50 AM
^^ same here sorta, but i think its the cd's i burn becuz "real" CDs work fine in my deck, but when i hit corners im gettin this issue.
Old Apr 14, 2007 | 08:26 AM
cs82685's Avatar
I've actually noticed the same problem on my stock stereo. It will happen once in a while, very randomly and then it will go away One day if I decide to not be lazy I'll try and figure it out.
Old Apr 14, 2007 | 08:45 AM
my 03 never did this tho :/
Old Apr 14, 2007 | 09:08 AM
kiley_sean's Avatar
Too much G-force, Maverick.
You killed Goose, so the request for fly-by is denied.
Old Apr 14, 2007 | 09:31 AM
KawRider's Avatar
Stupid Mitshbishi Grounds the stock readio through the Antenna connection. Make sure that it is tight.
SOUL STEALER
Mar 30, 2012 12:57 PM
JacobKuiper
Sep 5, 2011 06:45 PM
cpunlamd
Jul 1, 2010 02:41 PM
SLVROZ_03
Southeast Region
Sep 25, 2005 09:09 AM
G20
Mar 6, 2005 10:05 PM
