Alarm / Security System Help
I bought a car that had a ghetto rigged security system on it and I am trying to remove it and return it to stock. Does anyone have a wiring diagram or a how to for wiring up the stock system? I just want the locks working again with the key fob. If no one even has these things, could you get me started in the right direction by telling me where the stock alarm system is located in the car? I have the dash out right now so it would be easy access if it is there. Thanks in advance!
Scott
Scott
Well, Im pretty sure the evo doesn't come with a stock alarm, only keyless entry. You might be able to just take out the old alarm if you can figure that out, but it might be easier to take it to a car audio place and see if they would remove it (assuming you could prove you owned the car)
Don't know if this will help, but I found it here
another evo viii and ix alarm wiring diagram
2005 MITSUBISHI LANCER 4DR SEDAN EVO VIII
Security
WIRE COLOR POLARITY LOCATION
Battery WHITE (+) IGNITION SWITCH HARNESS
Ignition 1 BLACK/WHITE (+) IGNITION SWITCH HARNESS
Starter 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
All Door Trigger WHITE (-) FUSEBOX , WHITE PLUG AT BOTTOM
Domelight Super USE DOOR TRIGGER
Trunk Trigger GREEN/ORANGE (-) TRUNK LIGHT
Alarm Disarm GRAY
Parking Lights GREEN/YELLOW (L) GREEN/WHITE (R) (+) FUSEBOX , WHITE PLUG AT BOTTOM
Convenience
Headlights-Lo RED/YELLOW (L) PINK (R) (+) RELAY CENTER UNDER HOOD
All Hazrd Lights WHITE (-) HAZARD SWITCH
Wipers-Lo BLUE/RED (+) WIPER MOTOR
Wipers-Hi ORANGE (+) WIPER MOTOR
Parking Brake BLUE/RED (-) PARKING BRAKE SWITCH
Remote Start
Accessory 1 BLUE/BLACK (+) IGNITION SWITCH HARNESS
Accessory 2 BLUE/WHITE (+) IGNITION SWITCH HARNESS
Anti-Theft Type SOME MODELS HAVE RF TYPE IMMOBILIZER SYSTEMS
Key Sense BLUE
RESTS AT GROUND OPEN WHEN KEY IS IN, USE RELAY TO OPEN.
Tachometer BLACK/YELLOW (-) IGNITION COIL
Speed Sense BLACK/RED (AC) DIAGNOSTIC CONNECTOR UNDER DRIVER DASH
Brake Lights GREEN (+) BRAKE SWITCH
Reverse Lights BROWN (+) DRIVER KICK PANEL, HARNESS TO REAR
Horn BLUE/RED OR RED (-) HORN SWITCH
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock LT.GREEN (-) DRIVER KICK DOOR HARNESS
PowerLock VIOLET (-) DRIVER KICK DOOR HARNESS
Driver Mtr Unlock WHITE (REV) DRIVER KICK DOOR HARNESS
Driver Mtr Lock BLUE/RED (AC) DRIVER KICK DOOR HARNESS
LF Window Up RED/BLACK (REV) DRIVER WINDOW SWITCH IN DOOR
LF Window Dn GREEN/BLACK (REV) DRIVER WINDOW SWITCH IN DOOR
RF Window Up BLUE/WHITE (REV) DRIVER KICK DOOR HARNESS
RF Window Dn BLACK/WHITE (REV) DRIVER KICK DOOR HARNESS
LR Window Up WHITE (REV) DRIVER KICK DOOR HARNESS
LR Window Dn BLUE (REV) DRIVER KICK DOOR HARNESS
RR Window Up BLUE/BLACK (REV) DRIVER KICK DOOR HARNESS
RR Window Dn GREEN/YELLOW (REV) DRIVER KICK DOOR HARNESS
Security
Alarm Disarm GRAY
Convenience
Remote Start
Key Sense BLUE
Modules
WIRE LOCATION
Doorlocks/Windows
jnick
16
Jun 30, 2015 03:35 PM
