SSL SUB Replacement idea
Old Apr 12, 2008 | 12:24 PM
Fast_Freddie's Avatar
Veteran: Navy
Well I have already replaced the stock SSL sub with a MTX 8" sub and a Rockford amp, and I just need more bass than that. I just bought a Pioneer shallow mount 10" 250w RMS and a new Alpine Mono amp that is 220w RMS. I plan on mounting the sub in the stock SSL box as well. I know that I will have to trim the hole a bit, but the holes for the speaker grille should be the same size as a 10... so we shall see. I know why don't I just get a fiberglass box..... I wan't my trunk to look as stock as possible, and with the SSL box in the back the carpet is trimmed for it and there is no need for 2 boxes if you can utilize that one. Hopefull everything will go off without a hitch as I am planning. I am on deployment at the moment but will be back shortly, and will give you guys an update after everything is installed.
Old Apr 13, 2008 | 04:41 AM
LayinLo's Avatar
I know some have had success with aftermarket 10" subs. Hopefully yours will be good too.
A lot of people overlook the shallow subs.
Good luck and definitely keep us posted!
Old Apr 19, 2008 | 09:33 PM
LaminarFlow's Avatar
I went ahead and built a 4th order box for my JL10. With a 4th order box, all the sound comes out a single port. I sent the 3" port up through the center seatbelt retractor hole into the cabin. It hits very well, with almost zero rattles. But certianly takes up more space in the trunk than the stock box, which i know defeats the space benifit of the stock box. I just can't imagine getting any good sound out of that stock box, even with a better driver.
Old Apr 24, 2008 | 08:32 PM
mrdecrypter's Avatar
yea i dont see how the stock SSL sub box has enough airspace to do any kind of upgrade. good luck with it though.
Old May 1, 2008 | 08:43 PM
Veteran: Navy
Well if you look at the reccomended airspace for the Pioneer shallow mount the stock box is almost dead on.... I will be adding polyfill also , so we shall see. I am still on deployment at the moment so I won't beable to install it for another month or so... I will post pics of the install, and give an update when I get back.
Old Jun 12, 2008 | 10:06 PM
Veteran: Navy
Ok finally got back home and put the Pioneer Premier shallow mount sub into the SSL box. It took a bit of fabrication, but I got it in, and it really sounds good! Alot more bass than the MTX 8 I had in the box, and it is still in the stock box. All in all I am very pleased with it.
Old Jun 13, 2008 | 03:28 AM
biggie5252's Avatar
Welcome home! Do you have any pics of the box?
Old Jun 13, 2008 | 03:57 AM
tim85851's Avatar
show us! i have ssl and was thinkin about gettin a bigger sub too...
Old Jun 13, 2008 | 10:41 AM
igo4bmx's Avatar
wow im totally thinking about taking out my 2 10 inch elemental 10ks and getting a single 8 for weight and space reasons.
i may build a spacer in an ssl sub box and run a 10!
Old Jun 13, 2008 | 04:47 PM
Craig King's Avatar
I've always been partial to JL subs.
Old Jun 14, 2008 | 08:56 PM
Veteran: Navy
JL makes some sick *** shallow mount subs now too....
I will post up some pics in a few days guys... been hella busy working on the car for the past few days... got everthing installed just trying to relax before I have to go back to work monday...
Old Jun 16, 2008 | 08:27 AM
igo4bmx's Avatar
hey guys
this is what im gonna use to mount a 10 inch woofer into an SSL box.
http://www.edesignaudio.com/ringbuilder_advanced.php
get a custom made 8 inch ring that extends out to a 10 inch ring to bring the sub out and alot it to clear the ssl box. I will be filling it with polyfill to get a larger airspace volume.
Old Jun 19, 2008 | 11:27 AM
Veteran: Navy
sorry I haven't posted pics yet guys, I am in the process of moving so I have been hella busy. I will get them up as soon as I can....
Old Jun 19, 2008 | 03:29 PM
itsme4g63's Avatar
How bout you make me a duplicate bolt in setup and I send you moneys?
Old Jun 20, 2008 | 07:24 AM
Veteran: Navy
I can do that if you want, but shipping is gonna kill you...
