Putting aftermarket deck in ssl package
Old May 23, 2008 | 03:25 PM
gstowner's Avatar
Hey guys,
I have an 04 viii with the ssl package. I am planning on putting a deck in that I can use my ipod with. I've heard of guys getting rca's and hardwiring them in, instead of ordering the "mitah" adapter. Does this hurt sound quality at all? I've searched and found that it seems like everyone just buys the adapter. Do you guys reccomend hardwiring it? Then stupid question but do I need a harness for my power plug?
Thanks!
Justin
Old May 23, 2008 | 05:57 PM
heel2toe's Avatar
your better off just ordering the adapter. You are also going to need a separate adapter for power ground antenna etc. If you order your deck from crutchfield they will include all of the adapters needed for the installation at no additional cost
Old May 26, 2008 | 10:04 PM
Fast_Freddie's Avatar
Veteran: Navy
Trust me just spend the money on teh MITAH adapter, it is painless and you wont botch the stock harness....
Old May 26, 2008 | 10:14 PM
biggie5252's Avatar
You might try reading the Evo audio info thread. There's some good info about using aftermarket headunit to ssl evos.
Old May 27, 2008 | 02:30 PM
Chemwarrior's Avatar
I also have the SSL with an aftermarket head unit. I would highly advise getting the MITAH/METRA adapters. It makes the installation so much easier. The aftermarket head unit also wakes up the system.
Old May 27, 2008 | 05:04 PM
gstowner's Avatar
Thanks for the replies guys! I ordered the adapter today, so I'm anxioius to get that baby in there!
Old Jun 27, 2008 | 12:29 PM
BlackTypeS's Avatar
what is MITAH adaptor?
Old Jul 1, 2008 | 09:40 AM
BlackTypeS's Avatar
Old Jul 8, 2008 | 10:47 AM
redboosted05's Avatar
this adapter actually come in the new metra packaging with the power/speaker harness for 20 bux at your local store!
Old Jul 10, 2008 | 11:11 AM
Veteran: Navy
Here is the run down... Basically the stock SSL radio has a low level output harness that feeds into the stock infinity amp. What the MITAH adapter does is turns the low level input harness into 2 sets fo RCA jacks so you can plug them directly into an aftermarket headunits pre-amp outputs... Painless install
Old Jul 10, 2008 | 01:25 PM
WhiteEvo05's Avatar
https://www.evolutionm.net/forums/sh...2&postcount=10
MITAH is the round adapter with the RCA's on the other end with the blue wire for the remote turn on of the factory SSL amp. Basically this feeds the preamp signal form the aftermarket deck to the factory amp.
Metra is the blocky looking white adapter that mates up to the aftermarket head unit plug for power, memory, backlight dimmer, etc... I have removed all the extra wires fromt eh metra harness in the above picture link.
kosteniuks17
Mar 16, 2014 09:35 AM
GSR9
Feb 27, 2013 05:29 PM
tetsuo12333
Mar 8, 2010 02:33 PM
SPOOLD
Jul 13, 2008 09:33 PM
smp3000
19
Mar 12, 2007 08:49 PM
