ignition switched power wire at ecu harnes
Old Aug 5, 2008 | 12:15 PM
discodino's Avatar
can someone tell me what pin and wire color i should use from the ecu harness , for ignition switched power, please help
Old Aug 5, 2008 | 12:20 PM
mitsuatb's Avatar
Orange wire on the cigrette lighter.
Old Aug 5, 2008 | 12:25 PM
04gsna's Avatar
why you want it from the ecu? any reason?
Old Aug 5, 2008 | 12:50 PM
discodino's Avatar
where else is an easy place to splice in
to get to the lighter u need to take apart the center console
Old Aug 5, 2008 | 12:54 PM
Evoryder's Avatar
what are you powering up and where will it be mounted?
Old Aug 5, 2008 | 11:21 PM
discodino's Avatar
Im installing, aem Wideband, And AEM tru-boost controller, on the A pillar in a dual gauge pod, and my meth kit, in the glovebox the wires are long enough to go anywhere,
the lighter seems good, but im not sure how to remove the center console to get to wires, unless there is an easier way to do it.
i had the boost gauge and the wideband powered from the lighter fuse, (wires held in by the fuse) but thats half *** and temprary . LOL
thanks all for ur help
Old Aug 5, 2008 | 11:29 PM
04gsna's Avatar
I would use another source.
Old Aug 6, 2008 | 04:29 AM
Evoryder's Avatar
tap into a 12v fuse and use a local ground. Or use one of the 12v pinouts from the ecu.
Old Aug 6, 2008 | 04:48 AM
discodino's Avatar
which pins would that be, and what color wire?
i got an 2006 EVO IX MR.
Also ... are the 12 v pinouts ur talking about switched by the ignition
Old Aug 6, 2008 | 05:06 AM
Evoryder's Avatar
http://www.ttp-engineering.com/TTP.IX.ecu.pdf
This is your ecu and yes they are powered when you turn your key to ignition.
okevolutionVIII
Jun 11, 2012 09:09 PM
tboboy
Aug 7, 2010 03:39 PM
tboboy
Jul 19, 2010 11:21 AM
ksaegusa
Nov 27, 2008 09:15 AM
t-dotlancer
Jul 24, 2007 07:51 AM
