Help!!!
Old Oct 19, 2008 | 02:22 PM
fknlowpsi's Avatar
Help!!!
ok i have posted in a couple of other threads and im looking for anyother insight...
so when i turn on my head light all my dash lights go off but my clock, check engine,and seat belt lights stay on and dim/ i have checked all fuses 3 times physically and with a check light to make sure both sides are getting power/ all exterior lights are working and functional/ unplugged dimmer scroller and pluged back in/ nothing/ i am lost/ could it be a relay? i do have an aftermarket head unit.
i am looking for any help.....
Old Oct 20, 2008 | 08:02 AM
fknlowpsi's Avatar
bump
Old Oct 20, 2008 | 03:41 PM
JdMeVo4's Avatar
I ment to post up on your problem earlier but, I was stealing internet time at work. Anyway I was looking at the wiring diagram for your car and it showed a lighting computer of sorts past the multifunction switch in the electrical series on your year evo, I didn't look at any other years to confirm if they also have them I just assumed they did.
Your going to have to remove the steering wheel bezel to gain access to the multifunction switch or your light switch. I'll look at these diagrams again to tell exactly which wires should and shouldn't have power pending on the position of the light switch. If you do however have power coming from the switch to this lighting ecu/module but not out of the ecu/module that's where your problem lies.
Old Oct 22, 2008 | 07:49 AM
fknlowpsi's Avatar
thats no fun. thanks man let me know anything
Old Oct 27, 2008 | 11:51 AM
fknlowpsi's Avatar
bumpy
Old Nov 14, 2008 | 03:09 PM
06WWMR's Avatar
Personally I'd look at your dimmer switch before anything. If you have an open in your switch, then it could possibly cause your lights to be off like that. I'd say do a resistance sweep on the dimmer roller and see what you come up with. It may also be a problem in the light switch itself, or the circuit that controls the lights on the dash from the switch.
Old Nov 14, 2008 | 03:17 PM
LancerEVA06's Avatar
do you have your dimmer/illumination wires connected correctly on your aftermarket head unit? if not there is most likely where the problem lies
Old Dec 3, 2008 | 08:31 AM
fknlowpsi's Avatar
still having issue? i dont have dimmer/ illumination wires connected to my after market headunit/ any other help???
Old Dec 31, 2008 | 08:58 AM
fknlowpsi's Avatar
could not having the dimmer/ illumination wire connected be causing this???
twrtoad
Lancer Troubleshooting
May 8, 2016 06:42 PM
pd6186
12
Jan 19, 2016 09:45 AM
Swartz017
Oct 19, 2015 05:17 PM
Weathergeek
Aug 24, 2015 08:48 AM
adupree
Aug 15, 2015 07:45 PM
