the easiest solution to relocate you climate control for 2din display
Old Oct 22, 2013 | 03:34 PM
  #256
chris.langlais's Avatar
Originally Posted by cyanide
I believe the OP had his controls fixed to the dash. The bezel that R.mutt is using is installed differently. The controls can't be fixed to the dash with this bezel. They have to be loose after relocated, and move in and out of the space freely as the bezel will be the only thing holding the controls in place.
Okay this sounds easy enough then not that Im afraid of doing a little work but its always nice to have things be a little more easy if possible just curious though but do you provide instrustions on how to install the bezel that you make? Again not that it matters Id most likely buy one anyway... also when would be the best time to get ahold of you or should I just shoot you an email now about a future purchase (if you decide to start making them again)
Old Oct 22, 2013 | 04:41 PM
  #257
cyanide's Avatar
I provide instructions for the bezel, and also for installing the dd headunit using the factory radio brakets with the jdm dd trim. You can contact me any time. I reply when I get the chance because I work shifts.
Old Nov 5, 2013 | 02:04 PM
  #258
R. Mutt's Avatar
Originally Posted by chris.langlais
Did you have to do the modifying the that OP said to do? Like, the cutting of the metal and such or did this product solve that in not having to do any of that?
I did have to cut the metal.
Old May 9, 2014 | 09:21 AM
  #259
Tatmonster45's Avatar
Different approach
I know this is an old thread but I wanted to try this and do it differently. This is a much easier way. Everything is the same except make 1 inch spacers for the bolts to mount the Ac . Trim out out control faceplate and don't even need to get all precise with it because your going to mount the faceplate on and then put the cubby over it. Comes out perfectly clean every time. Easy too I did the whole relocation in 45 min. Pm me if you have questions
Enjoy
Attached Thumbnails the easiest solution to relocate you climate control for 2din display-image.jpg
Old Sep 6, 2015 | 10:48 AM
  #260
kyoo's Avatar
part number for this screw?
Old Sep 14, 2015 | 10:37 PM
  #261
kyoo's Avatar
bump - any tips on getting the 2din to fit perfect? I think I'm going to have to cut those rubber studs off that support the back of the metal brackets, not fitting great with those sticking out
Old Jan 4, 2016 | 12:10 PM
  #262
I_want_MR's Avatar
So wanna try this with a GTR screen
Old Jul 27, 2016 | 10:47 AM
  #263
etang789's Avatar
Great write up! Though I don't need double din but it's going to be gauges and single din head unit at better eye level
Old Jul 27, 2016 | 03:40 PM
  #264
cyanide's Avatar
The era of making this these kits by hand died with Metra. Them being a big enough company, their mass production of these kits allowed them to be cheap enough to not making its build by hand worth it. That said, here's the company that used to make them for me: http://www.custominstallparts.com/st..._-_CUSTOM.html. You can find the Metra kit by googling as it is mostly found through their retailers.
My website is still active, so for pics of the kit linked above, visit: http://www.prtc.net/~cjramos54/Gallery.html. No sales are being done through the site, so if you're looking into getting this kit, visit the link above, or google the metra kit.
For installation instructions, email me at evohvacbezel@gmail.com
Old Jul 27, 2016 | 06:49 PM
  #265
etang789's Avatar
Thanks didn't know Metra makes the AC control kit as well!
Old Aug 13, 2016 | 07:09 AM
  #266
Ameliorate's Avatar
makes things alot easier, thanks
Old Oct 9, 2016 | 05:24 AM
  #267
primokills's Avatar
I'm trying to move it down but something keeps snapping it back into place
Old Dec 4, 2016 | 01:30 AM
  #268
Nads's Avatar
Also working on lowering hvac panel. Is finishing good?
Old Dec 4, 2016 | 01:37 AM
  #269
Nads's Avatar
Deleted.
Old Dec 4, 2016 | 05:31 AM
  #270
cyanide's Avatar
Kits are now cheap: http://www.custominstallparts.com/st..._-_CUSTOM.html. Also, google "lancer metra" in images and you'll find the Metra version. No need for the hassle with wiring for the Galant HVAC or fabrication.
