the easiest solution to relocate you climate control for 2din display
Old Mar 17, 2009 | 12:52 PM
  #106
__pg's Avatar
Yes my controls work perfectly. I just reran all the cables down to the lower cubby and it worked fine. Do you have an 8 or 9? Wonder if there is a small difference between the 2?
Old Mar 26, 2009 | 09:59 PM
  #107
N33d4sp33d's Avatar
very well done...NOW WHERE CAN I GET THIS KIT ???
Old Mar 27, 2009 | 03:01 PM
  #108
GEVOVIII's Avatar
great post. i was wondering how everyone was doing this lol
Old Mar 27, 2009 | 06:14 PM
  #109
donmeca2020's Avatar
look point blank if you guys are coming in here asking if this is hard? the answer is NO AS LONG as you have a full free day and someone willing to help out on the project. it took me early morning saturday til almost night time that day to finish it up. the only hard part i felt was the removing the A/C wires other then that it was all cake as long as you have someone helping you out.
Old Apr 13, 2009 | 09:41 AM
  #110
Darkn3s's Avatar
nice little diy and CHEAP!
Old Apr 14, 2009 | 06:59 AM
  #111
Nelissen's Avatar
I have done it today, easy to do alone, i did it in 4 hours .
everything works perfect.
Eric
Old Apr 14, 2009 | 08:37 AM
  #112
kinglasserres's Avatar
Its good to hear that some of you guy did my solution and thinks its one of the "good" DIY mods out there. for all of you are satisfied with the mod and have actually done it. thank you for the compliment.
Old May 4, 2009 | 08:30 PM
  #113
EvoBullet06's Avatar
hmmm... more surgery than I thought. Still obviously very do-able! double din from japanparts.com?
Old May 5, 2009 | 10:13 AM
  #114
cbuster77's Avatar
def an excellent idea,good write up man
Old May 31, 2009 | 11:50 AM
  #115
bambooi's Avatar
why is everyone picking the avic f90bt
Old Jun 3, 2009 | 10:27 AM
  #116
CJAYx47's Avatar
hey the op said there is a metal piece inside the cubby hole that needs to be cut, what metal piece is that?
thanks
Old Jun 3, 2009 | 01:17 PM
  #117
TKEVO's Avatar
Veteran: Air Force
Nice post. Something i had in mind or im doing another custom job
Old Jun 3, 2009 | 05:06 PM
  #118
thanks
Sorry but i lost the pic on the 1st page. The metal part is the one inside the lower cubby left part. If you already pulled out your climent control unit and try to installed it on the botton your will see that it wont fit and that metal thing is in the way. Thats the one you have to cut. Is easier to cut that if you remove it by unscrewing the bolts.
Old Jun 3, 2009 | 06:06 PM
  #119
CJAYx47's Avatar
hmmmmm is it the bolt looking piece ?
Old Jun 5, 2009 | 10:53 PM
  #120
unsungboxer's Avatar
thanks
Instead of cutting the metal pieces, it makes much more sense to simply remove them. They are brackets that are mounted left and right. Simply remove the 10mm bolts that hold each one of them in. I have done this with success. No change in structural integrity. (when removing the bolts, watch your hands. these brackets are unfinished and sharp as heck.)
note: I did this for a carpc project that did not require using the brackets to mount a double-din head unit. if you plan to use these brackets for mounting purposes, you may as well modify the brackets and keep them in.
