the easiest solution to relocate you climate control for 2din display
Old Feb 10, 2010 | 11:01 AM
  #196
tsair's Avatar
Originally Posted by oxyigen
Ya they barely reached, but the problem I am having right now is that whenever I turn the temp around, it would never reach fully anymore, it will never get hot or cold, i can feel it is loose inside, any idea of how to fix it ?
So the cable is properly attached and the dials are turning fine and you see the cable being pulled/pushed within their sleeves?
Sounds like either the cable has been cut or the other end is not working right. I have no idea what the other end of the cable is attached to.
Old Feb 11, 2010 | 06:17 AM
  #197
MidniteEco's Avatar
The temp cable just moves a damper back & forth to select the mix of hot and cold air. The cable is only like 8" long. You should be able to see where it attaches to the damper under the dash and watch as your turn the knob. The cable should move the damper while the cable's sheath (blue or black) should remain in place. Each end of the sheath has a metal clip to hold it in place and I had some issues getting that clip to stay in place. The clip wraps around the sheath and then clips into the white plastic under the dash. I had to use a small pliers to fix its shape so it would stay clipped into the white plastic.
Old Feb 11, 2010 | 06:34 AM
  #198
need_an_evo's Avatar
nice write up man
Old Aug 1, 2010 | 08:38 AM
  #199
tsair's Avatar
instructions again for people who want to cut their own
Old Aug 5, 2010 | 08:39 PM
  #200
edwin's Avatar
or you can try this:
https://www.evolutionm.net/forums/ev...ml#post8559166
Old Aug 10, 2010 | 03:30 PM
  #201
evo9nuuub's Avatar
might be a dumb question but why not keep the mechanical hvac and just use the knobs and panel face from the digital setup?
everything looks like its in the same location, so the recirc and ac buttons would still work
Old Aug 15, 2010 | 07:42 AM
  #202
YoManStation's Avatar
Great job guys, i would like to have one done too
Old Sep 2, 2010 | 06:28 PM
  #203
DJAfterShok's Avatar
Deff going to try and get creative with the dremal tool when i get home. I'm sure i could possibly make a face plate and then just put it on the stereo relocation kit. I seen the climate control "stickers" on ebay so it will be something that i will deff try out.
Old Sep 4, 2010 | 07:00 PM
  #204
unsungboxer's Avatar
climate control stickers are for sale directly from mitsubishi for about 10 bucks. visit www.mitsubishiparts.net
Part # Description Price
MR568314 Label,heater Cont $3.63
MR500935 Label,heater Cont $3.63
MR500932 Label,heater Cont $2.62
Subtotal: $9.88
Old Sep 4, 2010 | 07:28 PM
  #205
abysmal's Avatar
nice write up....
Old Oct 31, 2010 | 02:52 PM
  #206
cyanide's Avatar
Subtotal: $9.88
There's also a custom solution, but not as cheap...
http://www.caribbeancustomdesigns.co...5994d6426673a6
I got these on black with white illumination, but I never took took daytime pics of it. All I have is this:
I replaced the factory bulbs with LED ones, so that's why the white is so bright.
Old Nov 2, 2010 | 12:07 PM
  #207
benderrodriguez's Avatar
This rocks!
Old Dec 14, 2010 | 08:10 AM
  #208
BOOSTINAT30PSI's Avatar
Great info. Thanks!
Old Jan 3, 2011 | 07:06 PM
  #209
tpdc2's Avatar
anybody ever find a trim plate that makes the double din look flush?
Old Jan 20, 2011 | 08:23 AM
  #210
shangai's Avatar
Originally Posted by edwin
that link doesnt work man
