How to Splice into Wires on the ECU Harness??
Old Mar 18, 2009 | 06:24 AM
LetsGo82nd's Avatar
I am getting ready to install a Greddy Turbo timer w/ harness and the project seems very straight forward. My only question is about how exactly I go about splicing into the Speed sensor wire on the ECU and the parking break wire? I am sure it is very simple but I would just like to make sure as I don't have any experience doing it. Do I simply strip the wires and connect them? On one of the walk throughs in the How To Section it looked like there might be a plastic junction piece that can be used for splicing? Thanks a lot for the help.
Old Mar 18, 2009 | 06:37 AM
4G63K's Avatar
I used these when i did mine. And they worked very well.
You can pick them up at a local Automotive store.
Old Mar 18, 2009 | 08:04 AM
LetsGo82nd's Avatar
Ok, that is exactly what I was looking for. So it looks like your just laying the sections of stripped wires across this and closing the clamp?
Old Mar 18, 2009 | 08:06 AM
bmguser's Avatar
i think there are those boomslang harnesses that you can get if you dont want to cut into the factory harness...
Old Mar 18, 2009 | 08:15 AM
LetsGo82nd's Avatar
How much do those cost and who makes them? Thanks for the info.
Old Mar 18, 2009 | 08:32 AM
4G63K's Avatar
all you have to do is basically put the wire in that you want splice into and than put your tt wire in on the other side and close it. the connector cuts into the wire once you close it. you should only have splice into two wires. The brake and the ecu.
This is the wire harness:
http://evomoto.com/product_info.php?...6d4297223c2bf1
and this a good write up:
http://evomoto.com/tech_info.php?tPa...93279dd1577bc2
Good luck.
Old Mar 18, 2009 | 08:53 AM
LetsGo82nd's Avatar
Thanks for all the info. Do you happen to know the name of the part you posted a picture of, so that I can ask for the right thing at the automotive store? Thanks.
Old Mar 18, 2009 | 08:58 AM
Fast_Freddie's Avatar
Veteran: Navy
Just ask for a vampire splice... they should be able to help you then...
Old Mar 18, 2009 | 08:59 AM
4G63K's Avatar
Use some Snap-lock Connectors. They are cheap. You slide them over the wire, and insert the new wire into a hole on them. When you push down on the metal blade, it straddles and cuts the insulation.
Good Luck.
Old Mar 18, 2009 | 09:06 AM
LetsGo82nd's Avatar
Really apprecaite all the help guys, now I don't have to pay someone else to do something that really doesn't seem very hard.
Old Mar 18, 2009 | 10:02 AM
4G63K's Avatar
It isnt hard. Just patiance, with taking off all the plastic.
Old Mar 18, 2009 | 10:15 AM
hotrod2448's Avatar
The splices are mainly referred to as scotchloks.
DJGrunta
Oct 27, 2014 12:11 AM
basicwizz
Jun 29, 2011 01:13 PM
CarFanatic
Mar 6, 2007 12:53 PM
dreamevo
May 20, 2005 03:16 PM
Coolguy949
12
May 30, 2003 03:43 PM
