Removal of top part of dash
Old Mar 21, 2009 | 05:23 PM
oxymoron's Avatar
Im wanting to know if anyone has or knows how to remove the top section of the dash.
I want to have it re-trimmed in suede to give it a look similar too a porsche/ferrari.
I also need to know how to disable the passenger air bag if anyone knows that too.
cheers
Old Mar 22, 2009 | 05:21 AM
murderedevo256's Avatar
I second this
Old Mar 22, 2009 | 08:26 PM
oneguy's Avatar
i third this
Old Mar 22, 2009 | 08:51 PM
xspsi4's Avatar
You can not remove the "pad" fom the actual dash even though it looks like you can.
Old Mar 22, 2009 | 09:29 PM
evoww's Avatar
top pad
in actuality you can remove the top part of the dash im just in the process and i don't see anyway else but to remove the whole dash but if some else know to do this please let us know
Old Mar 22, 2009 | 09:54 PM
xspsi4's Avatar
I am looking at a dash right now and trust me they are not 2 pieces even though it appears to be.
Old Mar 23, 2009 | 09:29 AM
evoww's Avatar
dash top
i bought a wrecked evo and i am in the process of putting it back together the air bags deployed i bought just the top of the dash on line so for sure it is two pieces and can be separated.
Old Mar 24, 2009 | 12:21 PM
Fireball's Avatar
I have done this to a wrecked Evo.
The only way is to take the entire dash out.
It's quite the process. Basically there's no way to detail how to do it, due to the number of screws and bolts you run into.
Simply stated: Take everything off the dash you can. Radio, Trays, Buttons, Gauge Cluster, etc.
Then remove every single screw and bolt you find that is attached to the dash.
Once you get the entire plastic dash assembly out, you can flip it over and remove about 20 more screws which hold the top cover on.
Old Mar 24, 2009 | 12:51 PM
jmcevo1's Avatar
You can remove the dash pad I have done it on my 04 VIII. The problem is you have take the entire dash out of the car first. I had mine painted and it took myself and my friend about two hours for removal its really not that bad, just a ton of screws to remove and time consumeing! However the results where very good!! Hope this helps pm me with any specific questions!!
Old Mar 24, 2009 | 06:52 PM
oxymoron's Avatar
Sounds like a bit of work but at least it is do-able. Thanks everyone
edit: jmcevo1, was it harder or easier to get it back in?
Is the airbag going to blow on me if i start undoing the dash or can I just make sure the fuse is removed or disconnect the battery?
timdog4life
10
Aug 24, 2018 09:47 PM
Fireball
10
Mar 1, 2012 01:04 PM
TKEVO
Feb 24, 2008 12:20 PM
Pick_a_Fro
Aug 9, 2004 09:09 PM
t-dotlancer
Jun 12, 2003 03:46 PM
