Two Batteries?
Old Aug 1, 2009 | 05:45 PM
TwistedDreams's Avatar
Two Batteries?
Has anyone ever installed a small battery in place of the stock battery under the hood, and had that only be used for everything but the sound system, then installed another full size battery in the trunk for only the sound system? Just curious if it's been done, mostly.
-TD
Old Aug 1, 2009 | 05:55 PM
Evoryder's Avatar
Optima red top/yellow top in the trunk. close thread.
Old Aug 1, 2009 | 06:16 PM
Well no I was hoping to see some setups....
Old Aug 2, 2009 | 07:40 AM
FJF's Avatar
FJF
-TD
If you plan the system well, you won't need another battery and its added weight.
Old Aug 2, 2009 | 12:09 PM
^well a small battery is only 20 pounds, so It'd only be a battery relocation to the trunk, so it'd still be less weight up front and better overall weight distribution. I want to do this because I want to run my sound system for long periods of time and not have to worry about running out of battery to start my car. Will this be easy to wire up?
-TD
Old Aug 2, 2009 | 07:25 PM
sphinxof2006's Avatar
i was planning on doing the same thing i wanna see some setups as well
Old Aug 4, 2009 | 07:21 AM
igo4bmx's Avatar
-TD
to be clear you run your car audio with the car not running?
if so you need a battery isolator.
http://www.bcae1.com/battiso.htm
Old Aug 4, 2009 | 07:23 AM
igo4bmx's Avatar
some safety info
If the battery is inside the passenger (in a hatchback vehicle or in a car with a back seat that folds down), you must use a sealed battery (i.e. Optima). If the battery is being used in the trunk of a vehicle you can use a standard battery but you will need put the battery in a battery box and you will need to provide proper ventillation. Proper ventillation would mean forced air (fan) ventilation from the battery box to the outside of the vehicle. When a standard lead acid battery charges, it produces flammable gases which must be removed from the vehicle to prevent a fire/explosion hazard.
Old Aug 4, 2009 | 09:09 AM
Those diagrams are interesting and I've read it all and trying to figure it out. haha but thanks I think that's pretty much what I was looking for.
-TD
Old Aug 9, 2009 | 07:04 PM
EvolutionBOOM's Avatar
just use optima yellow top in the trunk
DaRw1n
Oct 21, 2016 05:51 PM
evoiao
Dec 31, 2012 12:03 PM
AWDralliart09
Apr 5, 2012 09:02 AM
atombomb33
Oct 20, 2007 07:09 PM
OZLancerlunatic
Lancer Engine Tech
Feb 5, 2002 11:53 PM
