Radio cuts out with high volume
Old Aug 27, 2009 | 11:55 PM
red evo8's Avatar
I have an alpine iva d300 dvd player installed in my car , the place that installed it is no longer in business so i'm stuck. The radio basically turns off when the music gets remotely loud so what could the problem be??
Old Aug 28, 2009 | 08:34 AM
FJF's Avatar
FJF
Is there an amplifier? If not, what speakers is the HU driving? If I understood correctly, the HU, itself, turn off. Does it lose power or does the sound cut out?
Old Aug 28, 2009 | 12:38 PM
red evo8's Avatar
The hu turns off like it is turned off no lights no sounds etc. and then it turns back on in about 2 seconds, their is an amplifier but the alpine has a brain that was spliced into my factory amplifier, my evo was the ssl edition with the upgraded audio system.
speakers are w/e came with the 06 ssl evo i think jl?
Old Aug 28, 2009 | 10:51 PM
NWEvoViii's Avatar
When I run into cases like these, Usually it's the amplifier that is causing everything to shut off when it gets loud. Has this just been happening recently? And when you say there is an amplifier is there an aftermarket one or just the stock one? Or both?
Old Aug 30, 2009 | 02:13 AM
red evo8's Avatar
there is a stock one and it happens when ever the radio is turned up, i dont turn it up much so i usually ignore it but its getting annoying now.
Old Aug 30, 2009 | 04:51 AM
kmcconn9's Avatar
Theres your problem. When they integrated with stock amp with your iva d300, a speaker was wired out of phase.
Thus, when you turn up the radio, the radio is seeing a bunch of distortion, and thus shuts off..
Did they cut into the original harness, or simply use an adapter? Like the Soundgate MITS AMP??
Old Sep 1, 2009 | 02:38 PM
falcontx's Avatar
Also, if you haven't already done so, be sure to disable the internal amp on the Alpine. If the amp is on and doesn't have speakers attached to it, it will overheat, which could be another possible reason for the problem.
Old Jul 9, 2010 | 12:01 AM
02-Lancer-Es's Avatar
Was this ever fixed?
If not i had the exact same problem and it was that there was a weak ground on the stereo .
johntrav
15
Aug 1, 2016 05:04 PM
MatcoBill
Jun 30, 2011 06:46 PM
BlackSE
Aug 28, 2010 09:00 PM
mdinubil
Feb 5, 2008 03:01 PM
Jake26
Jun 6, 2007 12:29 PM
