perrin short shifter
Old Feb 6, 2010 | 11:31 AM
darkunitzero's Avatar
So I recently bought the Perrin short shifter and had a few questions about the install.
I'm currently referencing this thread for the install but the OP never mentioned the huge metal spacers included with the kit. The instructions call for:
Use supplied spacers under the back 2 mounting points of the shifter box. Use longer supplied bolts. Tighten to factory
spec.
But, I have not seen anyone use these in their installs or how they used it. Compared to the stock rubber mounters they're rather tall.
Any help would be awesome, thanks
edit:
So I tried to order these short shifter parts from my local Capital Mitsu, here in the Bay Area and they claim that their system does not register the parts as EVO specific
MR246296 Retainer,gearshif <they don't have part number
MR232147 Bushing,gearshift <not for an evo
But after some research, most retailers do carry these parts and they are listed as an evo part... Weird....
Old Feb 6, 2010 | 11:49 AM
Kracka's Avatar
You should use the taller bushings to lift the shifter cage up slightly to allow better alignment of the lower shifter cable. The Fidanza and eBay short-shifter kits also come with taller bushings for this reason. Here are Perrin's instructions: http://perrinperformance.com/shared/.../pepinr200.pdf
The part numbers you listed are correct. Required (unless you want to cut your stock shifter in half) is 1 x MR246296. 2 x MR232147 is optional, but it makes installation easier since you don't have to remove them from your stock shifter and risk damaging them. They may not be Evo-specific though, I think the newer Eclipse and regular Lancers use the same shifter assembly as the VIII/IX.
Old Feb 6, 2010 | 12:34 PM
Thanks for the confirmation, I ordered the necessary parts.
The kit I received came with 4 metal spacer instead of 2 called for by the instructions. So again, thanks for clearing that up as well.
Kracka
83
Jan 20, 2017 12:54 PM
i love my evo
25
Jul 15, 2016 09:01 PM
TWM Performance
Feb 20, 2012 11:14 AM
darkunitzero
Feb 18, 2010 10:46 AM
