Lost power to radio after gauge install
Old May 15, 2010 | 06:55 PM
twnty100drummer's Avatar
The guy that had the car before me tapped his boost gauge into the stock radio harness (red/black and yellow/blue). I removed his gauge today and put in 3 new ones with a gruppe-s tripple pod, and wired them up. The AFR I put in is the only one wired to the red/black constant 12v, the other 2 are wired to the yellow/blue. Everything was fine until I went to wire the AFR in. After I wired it up, I get no power to my radio or the AFR gauge.
I know what you are thinking, check fuse 23....I did, it was blown so I changed it but still no radio(I haven't checked it again). Any suggestions as to what it might be?
Old May 15, 2010 | 07:23 PM
dookgvr4's Avatar
sounds like a blown fuse to me.....
Old May 15, 2010 | 07:32 PM
Yeah I'm going to check it again tomorrow. Are there any radio fuses under the dash that I should check?
Old May 15, 2010 | 08:16 PM
dookgvr4's Avatar
I dont know off hand... do you have your user's manual in the glove box?..
They map out all the fuses for you in there and just check the ones in relation to the work you performed.
I would definitly start there.
Old May 19, 2010 | 01:56 PM
primetime's Avatar
Call me 646 229 5299 I'm a mecp certified tech that used to install car audio at circuit city ez fix my name is Vaughn
Old May 25, 2010 | 03:21 PM
hitman28's Avatar
^howd it go?
Old May 26, 2010 | 11:08 AM
The problem somehow resolved itself. My guess is that I have a wire loose in the radio harness. I check all the connections using a multimeter and it all checked out. Everything magically works fine now, but at least it wasnt gremlins!
Old May 31, 2010 | 06:14 PM
toxic-evo's Avatar
the deck in the evo grounds itself out when its set in place thru the metal.. so if u were trying to power it on when the deck wasnt in place it wouldnt work. that might not have been your issue, but thought id throw it out there
Old Jun 13, 2010 | 02:52 PM
evo_you_know's Avatar
just to let you know if your wide band sensor does not have power and you drive your car you can hurt the sensor. I would run it off of a deadicated circuit if you can.
sparcomx
19
Jun 1, 2013 12:37 PM
joon82
Feb 5, 2009 05:50 PM
c900t16
Nov 21, 2007 10:08 AM
boosting101
Oct 2, 2005 04:54 PM
qbbraveheart
Mar 18, 2005 08:48 AM
