Heater does not work
Old Nov 2, 2010 | 04:25 PM
HumanWeapon's Avatar
So my evos heat does not work at all. i can get air coming through the vents and the air conditioning works. its an evo 8 body with an evo 9 engine. im thinking that the heater core just isnt hooked up. Any other ideas?
Old Nov 2, 2010 | 04:36 PM
ShiftEvoVIII's Avatar
Did you look to see if the heater core connected? If you suspect thats the problem its a good place to start and its simple to look and see.
Old Nov 23, 2010 | 03:12 PM
dszast's Avatar
Look!!
Under the dash, just above the gas pedal on the white box which would be your blend door... have a buddy turn the knob to the heat side and then back and forth while u look under the dash until u see the problem. The blend door has to be closed for your heat to work. So turn the knob to heat and push up on the gear/door. It sounds complicated but its easy. Happens to a lot of evos and the cable that controls your heat is a good amount of money. In no time you will figure out how to do it while you are driving. Lol
Old Dec 4, 2010 | 10:30 AM
Force 6's Avatar
lol
Old Dec 18, 2010 | 01:15 PM
Rough_draft's Avatar
That worked for me ^
Old Dec 18, 2010 | 01:51 PM
Bigdawgmotors's Avatar
is your coolant at the proper level? do u have a coolant leak. or thermostat?
Old Dec 27, 2010 | 12:51 AM
EvoSeanzie's Avatar
oh my god. Im so glad I found this :-D
Old Jan 8, 2011 | 03:46 PM
awdordie's Avatar
Plus one on this my toes were numb until yesterday.
