VIII Wing re clear help.
Old Nov 15, 2011 | 04:52 PM
DSMolition's Avatar
My clear on my wing has yellowed a bit on top and the bottom corners have chipped away all of the clear coat down to the cf in 2 spots.
I took my wing into my bodyshop that i have good luck with and they quoted me 100 to sand down and re clear it.
I dropped it off and they started work on it. They started to sand down a little area to see how it would go and they are scared the carbon fiber will chip away and it will wreck the wing. What should I tell them to try as i have no experience with painting??
I have read that you need to go vary slow and work your way to 2000 grit with a sanding block to get the surface even. Also that you dont want to create heat so do not use a electric sander. Anything else I should consiter telling them.? I'm almost temped to try and do it myself.
Old Nov 15, 2011 | 05:47 PM
mt057's Avatar
If you sand/scuff/scratch the carbon fiber weave it will mess it up. Be very careful. I had mine done and it is better looking but not very good.
I hope your shop is better than the one I used.
Good luck
Old Nov 16, 2011 | 05:27 AM
DSMolition's Avatar
Thats what im scared about. I would rather leave it than have them make it look ****ty. I think ill have them sand it down a little bit and reclear it before they get to the cf. Idk
Old Nov 16, 2011 | 05:36 AM
slabbadabba's Avatar
https://www.evolutionm.net/forums/ev...bon-wings.html
try it yourself
Old Nov 16, 2011 | 07:58 AM
black_beauty's Avatar
Any good shop should easily be able to make it look like new again, I had my trunk and wing redone and it came out great
Old Nov 16, 2011 | 08:16 AM
GaBe511's Avatar
I might have to do mine myself. My body shop did not want to attempt it. Instead, he just wanted to paint it black.
Old Nov 16, 2011 | 03:05 PM
whitesnake's Avatar
I was even thinking of the vinyl wrap! Mines just now starting to peel up and I've had it since 04
Old Nov 17, 2011 | 05:37 AM
DSMolition's Avatar
Im going to call them today and see what they came up with.
Trever007
Jun 12, 2014 01:06 PM
DYTNEvo
Apr 21, 2013 02:14 PM
fafaforza
Jan 19, 2012 08:49 AM
meggs00
Oct 7, 2010 02:29 PM
