HVAC controls issues (possible short)
So while driving from work today, my climate control went out. I mean I wasn't able to turn on the fan or anything. At the same time, the ABS and all 3 of the ACD lights stayed constantly lit...
When I turned on the car, the ACD light would show Tarmac and suddenly all 3 would turn on. ABS would stay on as well.
No fuses were blown from what I can see.
I'm pretty sure it's not an ACD/ABS issue but I think an errant wire (one of the leads for the powered antenna) caused a short on the climate control panel. Not sure how to test the ACD, but the ABS definitely works.
Do you guys think that it's possible that a short on that would cause the other lights to be affected?
What else can I check or how can I troubleshoot this?
Thanks in advance
Thanks in advance
Find a solution yet for this? I see you started this thread back in late February.
Did you do anything in that general area recently?
Make sure it is plugged in (plug behind the 3 knobs - remove stereo to see better) properly, double check fuses in the engine bay and on drivers side (I would check both just in case).
havent found a solution yet. im going nuts, theres an AC relay that as soon as i plug it in the fan starts running and doesnt turn off. and my hvac still will not turn on. plus the abs and acd lights....im convinced that theres a short inside of my actual fuse box but who knows
xceler8rob
Feb 29, 2016 09:58 AM
foxbear2277
12
Dec 3, 2013 03:41 PM
Paul Nelson
15
Apr 18, 2007 06:25 PM
