acd fluids low!!! help
Old Jul 1, 2008 | 07:26 PM
ym3n3's Avatar
hello does anyone know where can i buy acd fluids? or does the dealers sell them and how much they charging?
my acd lightS all came on sometimes is it possible that the fluid running low caused it?
thanks guys
Old Jul 1, 2008 | 08:33 PM
Ph3n1x's Avatar
Mitsubishi Dealership
Its like 7 bucks a quart. Diamond ATF SP III
and yes low fluid can cause 3 lights.
Old Jul 1, 2008 | 08:40 PM
EvoJoeIX's Avatar
check for a leak.
find out where that fluid is going
Old Jul 1, 2008 | 08:41 PM
mac214's Avatar
Make sure to get the correct Mitsubishi fluid as stated above.
The reservoir is the one on the front driver's side of the car. There is a min/max line and the fluid is red.
Did you just do a clutch install? Was the ACD bolt on the transfer case torqued to the correct spec?
Old Jul 2, 2008 | 04:07 AM
ym3n3's Avatar
yes the red fluids on the driver side right behind the headlight.. the lvl is below min... is it possible to fill them up myself? just open and fill them back up right? how do u check if theres a leak? thanks guys
Old Jul 2, 2008 | 07:52 AM
mac214's Avatar
Yea, you need to get some more fluid in there.
Start following the lines and see if there are any visible leaks. Check on the top of the transfer case where the line goes and see if it is leaking there.
Did you do a clutch recently or have any of the lines disconnected?
Old Jul 2, 2008 | 07:57 AM
ym3n3's Avatar
nah didnt do anything.. i hope its not the acd pump =(
question acd fluid also called sp3 right?
Old Jul 2, 2008 | 08:16 AM
RussellM's Avatar
Plat Vendor
Here is a link with the fluid if you need to order some up.
http://www.mitsubishiparts.net/cart/...&pn=ACH1ZC1X05
Old Jul 2, 2008 | 01:12 PM
shivaswrath's Avatar
Russel for the other trans fluids, will 1 Gallon of Diaqueen 75w85 and 1 gallon of LSD SAE 90 cover an entire flush, or is more needed?
Old Jul 2, 2008 | 09:11 PM
EvoJoeIX's Avatar
make sure your checking it when the car is cold and not been started in a while. while its running it will suck fluid down and look like its low.....
Old Jul 3, 2008 | 10:44 AM
tony gibson's Avatar
I use valvoline ATF spIII and have had zero problems....thats with 80,000 miles on the oe parts and 60,000 miles on the valvoline acd fluid.
4G63_Crazy
10
Apr 19, 2017 07:47 AM
RussellDaniel
Mar 28, 2016 10:07 AM
silentsniper605
15
Oct 14, 2015 05:33 AM
HAHAV8
Feb 21, 2012 10:36 AM
EVO-L-OV3
Sep 30, 2008 09:58 AM
