A/C compressor keep blowing up fuse
Old Jan 6, 2016 | 05:36 AM
kr_3c's Avatar
Exclamation A/C compressor keep blowing up fuse
So I live in a country with 30+ celcius almost everyday at 2:00 pm, I need the A/C
what I found is the A/C is not engaging right after I washed my car.
I did an A/C line change job before I went to wash the car. It was all cold and nice.
But when I drive back to my home. The A/C stopped working and start blowing hot air right before I drive it into the garage. So I was like what happened?
Did a check-out and found that the fuse was snapped. I changed the 20A fuse today and I drove it to my friends shop for a alignment( just blew my Tcase 2 days ago, after fix need an alignment), this time, the engine fuse snapped, the a/c fuse was totally melted. and now when I try to put fuse into it. the rain wiper start whipping the window by itself, I didn't touch the stick at the steering wheel and the A/C fuse will snap right away when I turn on my A/C switch.
So anyone has any idea what is wrong with it ? lol I was guessing the compressor coil has a short circuit. but might be somewhere else. cuz the rain wiper thing is juz too ridiculous.
P.S I bought a new A/C compressor. do u guys think it will fix the short circuit by replacing the whole unit? any input would be helpful. thx a lot!
Old Jan 6, 2016 | 07:58 AM
llDemonll's Avatar
you have wiring issues. start diagnosing with a multimeter and best of luck. electrical issues are the worst!
Old Jan 6, 2016 | 08:50 AM
kr_3c's Avatar
I'm scratching my head real hard right now lol need a diagram or sth. do I need to check the fuse box located under the right hand side of console?
Old Jan 7, 2016 | 02:56 PM
Biggiesacks's Avatar
If you are blowing fuses you have shorts. No way around getting down with a multimeter and chasing them down. Download a shop manual for wiring diagrams.
Old Jan 7, 2016 | 11:10 PM
barneyb's Avatar
https://www.evolutionm.net/forums/ev...s-how-fix.html
Old Jan 8, 2016 | 09:33 PM
kr_3c's Avatar
thx for the help everyone, found the problem, the wire on the a/c com was exposing and touching the metal part of the positioning bracket (metal) causing the shorts and the a/c com is done with its life lol no vac at all when seal up the holes with fingers and spin the clutch. so I decided to change the new one. the shorts causing the fuse box to melt and 2 of the wires were sticking with each other because of the heat. 1 is the a/c another one is the rain wiper. bypass the fuse box and made a standalone fuse for the a/c. now everything is working. thx u so much for the input.
p.s I bought this car from a friend of my friend. the harness inside the car is horrible. probably will have a harness job done real soon. swapping out the whole thing. will start a new thread about this.
AlexC330NY
Lancer Troubleshooting
Mar 29, 2016 08:36 AM
Darkn3s
Nov 20, 2013 07:49 AM
CS05Evo
10
Feb 23, 2009 11:54 AM
OtownEvo
15
Jun 9, 2007 06:54 PM
