Starting problem
Old Aug 24, 2017 | 10:20 PM
Evoguy!123's Avatar
Starting problem
When I start my car, it starts off slowly I thought It was my battery because it was low, so I replaced it. so still does the same thing, when I want to start it, it will just click and dont even crank and when I try it again it starts off slowly, could it be my switch?
Old Aug 25, 2017 | 03:24 PM
Evoguy!123's Avatar
Bump
Old Sep 2, 2017 | 10:45 AM
CDrinkH2O's Avatar
Here is the section from the FSM that includes troubleshooting the starter......
File Type: pdf
Old Sep 2, 2017 | 12:06 PM
4b11slayer's Avatar
Could be a starter with excess resistance. Or excess resistance in the power cable from battery to starter. Look for any signs of corrosion on cables or battery acid also raises resistance
Old Sep 2, 2017 | 12:51 PM
barneyb's Avatar
No. The ignition switch energizes an electromagnet on the starter (the solenoid) which closes yet another switch mounted on the starter. This second switch connects the starter directly to the battery. So, the ignition switch either does or doesn't close this second switch, depending on its condition.
There is a condition, when the battery is nearly dead, where there is enough power to close the solenoid switch until the solenoid switch closes. Then so much power goes to the starter (remember the battery is nearly dead) the solenoid switch is no longer held closed. Once the solenoid switch is open and the starter is off line, sufficient power is again available to close the solenoid. What you hear is a chattering noise as the solenoid cycles.
Old Sep 4, 2017 | 06:37 AM
Ude Lose's Avatar
Sounds very similar to a problem that I'm having, it's like I have to hold the key and the car stumbleshow to life.
Sometimes I even have to touch the gas pedal marginally.
Tommygun916
Jul 21, 2014 12:08 AM
EvolutionTheory
10
Nov 15, 2009 06:25 AM
TurbotrixRacing
Turbotrix Racing - Edison, NJ
Mar 1, 2005 09:49 AM
w2pac12345
Sep 7, 2004 05:44 AM
SinCityEvo
15
Jun 9, 2004 11:28 PM
