Starting issue
Old Jun 16, 2018 | 09:14 PM
Armando0766's Avatar
Starting issue
I'm having a starting issue with my evo 9. For some reason, typically in hot days, I would have to flick the ignition key several times to get it to crank. I've changed the battery, battery terminals, starter, ignition switch, alternator, clutch switch, starter relay AND I still have the issue. My best guess at this point is the wiring is getting old and with the heat causing it's getting resistance so it doesn't get the correct voltage. Has anyone experienced this? If so did you replace with new wiring and relay? Thanks
Old Jun 19, 2018 | 07:28 PM
JohnnyTSi's Avatar
Sounds like this: https://evolutionm.net/forums/evo-ge...ied-fixed.html
Old Jun 26, 2018 | 02:02 PM
Nope, as stated before I changed that and it's hooked up right. I managed to fix it. I was correct about the voltage and age of the wiring. Installed an inline relay and worked perfectly.
Old Jun 27, 2018 | 05:32 PM
JohnnyTSi's Avatar
uhhh - the fix listed in that thread is to install an in-line relay to boost voltage to the starter relay.
Glad you got it fixed.
John-
Kraise
Aug 22, 2017 03:40 PM
EvolutionTheory
10
Nov 15, 2009 06:25 AM
SavEVOIX
Dec 2, 2008 08:08 PM
Sleeksilver
Lancer Troubleshooting
Sep 6, 2008 05:35 PM
cheb evo
13
May 24, 2007 06:34 PM
