Battery Relocation Stuff
Old Jun 13, 2019 | 05:02 PM
nor11384's Avatar
FCOTM Winner
So threw a bracket together real quick out of some scrap.
It’s been raining here every day so haven’t had much time to work on it. I want to paint it but humidity is high here now. Spent quite a bit drilling the 2 bottom holes and rethreading since the previous owner broke both bolts in the holes. I think for rushing through it it came out ok. You can see the rats nest back there. All that will be fixed and nicely done with the evo x fuseable link. Hope the wires reach.
Old Jun 14, 2019 | 11:21 AM
nor11384's Avatar
FCOTM Winner
Look at this bull****. Some people shouldn’t be working on cars. Omg thank god I decided to do this.
Old Jun 14, 2019 | 12:34 PM
Biggiesacks's Avatar
when you read off your measurements I was afraid it was going to look something like that. Pretty hazardous to say the least. Taking on this project was definitely a good idea.
Old Jun 14, 2019 | 01:06 PM
nor11384's Avatar
FCOTM Winner
Yeah good thing. Now, with this bracket I’m afraid the cables won’t reach. Is it ok to use a splice kit on the 2 cables that doesn’t reach?
Old Jun 14, 2019 | 01:33 PM
nor11384's Avatar
FCOTM Winner
For this wondering this is how I routed the cable in mine.
Old Jun 14, 2019 | 02:03 PM
Jp7's Avatar
Jp7
This is exactly how I did mine. Check my thread for my photos and work. I also powder-coated it when I was done. I also fabricated a tig welded bracket for the box in the back.
Old Jun 14, 2019 | 02:05 PM
It's fine to extend the wires, just use the appropriate parts/technique for the wire gauge.
Old Jun 14, 2019 | 02:32 PM
nor11384's Avatar
FCOTM Winner
Omfg...I decided to start checking the wires. Look at this guys. They put it together with tape. I think it’s the alternators. Wow. I’m going to have to go through the whole thing. I’m so angry. Wtf...!!!!!
Old Jun 14, 2019 | 03:19 PM
Holy crap what a fire hazard. You have some good karma or something because that could easily have resulted in fire.
Old Jun 14, 2019 | 04:47 PM
nor11384's Avatar
FCOTM Winner
Yeah no wonder car was having electrical gremlins wow. I went over all the grounds on the engine bay cleaning them up. Tomorrow I hope to wire it all up. I bought 2 splice kits from Lowe’s. I hope that’s the correct way to lengthen those wires.
Old Jun 15, 2019 | 01:18 PM
nor11384's Avatar
FCOTM Winner
And another one...fabulous...yeesh...
Old Jun 15, 2019 | 04:46 PM
nor11384's Avatar
FCOTM Winner
Well getting there...
Old Jun 16, 2019 | 11:28 AM
nor11384's Avatar
FCOTM Winner
Engine bay finished. Now on the the trunk.
Old Jun 16, 2019 | 11:55 AM
Looking really good
The chassis ground point I have circled in yellow wasn't really meant to handle the full load of the starter, it was really meant to just be a chassis tie in for the battery. That cable would normally terminate directly to the battery negative terminal. So if it was me, I would add an additional chassis ground and then connect it back to that circled ground point with some 4 gauge or something. You could also just relocate it to a more solid place on the chassis. Sorry I meant to post about this earlier. If it doesn't get hot or anything while cranking or with all the stuff running then its probably fine as is.
Old Jun 16, 2019 | 12:59 PM
nor11384's Avatar
FCOTM Winner
Ok thx. I have extra 2 awg wire and also have the 4 awg I removed that was going to the battery before. Where do you recommend I tie it into? Maybe the existing transmission ground? From there to what’s circled in yellow? I wouldn’t mind adding some grounds I just don’t know where.
