Help, Loud Whistling noise
Old Mar 13, 2005 | 06:48 AM
Deepseadiver's Avatar
I have a tea kettle loud whistle when the boost starts to build. I am pretty sure it is coming from the my Lower I/C pipe where it meets the turbo. I plan on getting under the car today to try to fix it. I bought the Buschur Delux FMIC that is when it started and now it is louder after the dealear replaced my clutch.
Old Mar 13, 2005 | 08:29 PM
I fixed it. It was what I thought it was. The lower I/C pipe flange. I had to use some High temp RTV with the gasket, let it dry for a few hours. took it for a test drive and everything was fine. Now just waiting 24 hrs till I can turn the boost back up to 21PSI.
Old Mar 13, 2005 | 10:07 PM
BlazeGT4's Avatar
No kidding? I got that when I tried to re-use the OEM gasket with GReddy piping. I thought I had failed to tighten it enough. Turns out I just needed to use the thicker GReddy gasket.
Same gasket as the BOV (FYI).
Blaze
Old Mar 18, 2005 | 01:53 PM
showard232's Avatar
Check the tightness of the pipe coming off of the turbo going to the FMIC; these bolts are notorious for coming loose.
Old Mar 18, 2005 | 02:09 PM
Ev0ikon's Avatar
It's most likely an air leak. Do a leak test. Mine did that with a leak at the flange between the UpperIntercooler Pipe and the 1G Diverter valve(Buschur's setup). I used some red gasket maker material (looks like silicon tube) and waited a few hours to test drive. It's all nice and quiet now except for the sound of air rushing through my cone fitler.
Old May 14, 2011 | 06:44 PM
Colbyy's Avatar
Just realized how old this thread was after i read it all.. But anyway i got the same issue. I hear a whistle when cars just idling and at low revs before boost.. I can not find where its coming from.
Old May 15, 2011 | 08:19 PM
angelo77's Avatar
I'm having this same issue as well. I noticed it after i installed my ETS I/C piping, inter cooler, and intake. The sound happens at low rpms, at approximately between 10-4 psi under vacuum. Once i get the car into boost range, the sound goes away.
Besides clamping down my IC pipes and checking my BOV, is there any other suggestions on the cause or better the yet a solution :< Thanks in advance
blkdrgn09
25
Aug 5, 2015 04:57 AM
blackandredgts
Jan 1, 2014 07:26 AM
JT-KGY
32
May 17, 2010 05:28 AM
jasnm21
Apr 28, 2009 03:37 PM
EVOBrad
Oct 2, 2006 07:15 AM
