Help with lower IC pipe install
Old Oct 22, 2004 | 05:45 PM
zstryder's Avatar
Hey all, was trying to install a Greddy IC (with lower piping). As it turns out, the stock IC pipe that connects to the turbo curves in a way that the pipe itself somewhat blocks the bolt. Any ideas on how to get to it? I dunno if a stubby wrench would work (need someone with small *** hands) or maybe a flexible extension? That's the only thing left, all the other new pipes and the IC itself is on already (although I forgot to use lock washers on two of three IC brackets... will that matter?)
If anyone who has done the lower pipe install would let me know, thanks!
Old Oct 22, 2004 | 05:53 PM
MYEVOVIII's Avatar
I have been told you have to take the starter off to get to them. Can you use the factory elbow coming of the turbo like the AMS kit uses and just attach your rubber piece to it?
Old Oct 22, 2004 | 05:57 PM
DynoFlash's Avatar
I just removed the starter and I got on them very easily with a long 1/4 " drive and extension
A little hint - use black RTV sealer on the pipe surface that mates to the turbo to seal it well
Old Oct 22, 2004 | 05:58 PM
MYEVOVIII's Avatar
Also if you replace the stock turbo discharge tube with the Greddy one you will need some high temp sealant as there is no gasket with the Greddy one. Sorry if you already new this just thinking of things that might help you that have been forgotten by others.
Old Oct 22, 2004 | 05:59 PM
MYEVOVIII's Avatar
Oops sorry Al you must have been posting at the same time. Great minds think alike.
Old Oct 22, 2004 | 06:03 PM
DynoFlash's Avatar
word!
Old Oct 22, 2004 | 06:47 PM
zstryder's Avatar
Hmm... actually mine came with a gasket? It should be ok, I think. What's involved with taking out the starter? I was afraid to touch it cause I didn't wanna take anything off that I didn't have to.
Old Oct 22, 2004 | 08:48 PM
DynoFlash's Avatar
First step - disconnect battery
Remove under tray
Take off power cable to starter 12 mm nut and snap connector
Remove two 14 mm bolts holding starter - take starter off
Now you should be able to reach the turbo discharge pipe
Old Oct 23, 2004 | 03:28 PM
zstryder's Avatar
Hm, I just noticed.. the IC pipe to the turbo doesn't have a nipple on it. What do I do with that extra tube that connected to the stock pipe? I can't just leave it open...
Old Oct 24, 2004 | 01:02 PM
zstryder's Avatar
Okay, well, what I ended up doing was just taking out the T line between the actuator, the IC pipe, and the stock boost solenoid, and just used the supplied line to connect the actuator and the stock boost solenoid.
I haven't taken the car for a spin yet but I'm about to, so we'll see how that goes...
Old Oct 24, 2004 | 03:23 PM
zstryder's Avatar
Hm, I got a leak now between the IC pipe and turbo. None of the sockets I have are small enough to get in there and tighten the bolt completely... ideas?
nobodyphil
Jan 13, 2011 09:44 AM
landis507
May 30, 2008 01:18 PM
MitsuJoe
Sep 27, 2007 11:34 AM
bboy_RES
28
Aug 12, 2007 11:23 AM
yesevo
24
May 11, 2005 02:05 PM
