Stock compressor, 94 octane 375 HP
Old Nov 5, 2004 | 08:12 AM
Fourdoor's Avatar
Hey guys,
Yesterday I did some pump gas tunning at Godspeed on their dynapack AWD dyno while adjusting my GM boost control solenoid (controled by the AEM EMS). Dan was sceptical when I said my goal was 350 on pump gas. As we slowly raised the boost level run after run we passed through 350 HP at 17 psi From there I continued on up to 20 psi and a peak of 375 HP SAE. The uncorrected torque was 302 pretty much flat from 4000RPM to 5500RPM. When you apply SAE correction to the torque you get 320 lb-ft of torque in that range.
This is all with the stock 16G compressor, with titanium exhaust wheel and shaft and a 10.5 hot side housing. I will post up the dyno sheet this Sunday.
Keith
Old Nov 5, 2004 | 08:19 AM
Ted B's Avatar
I don't know why he was skeptical of 350whp on pump fuel, as there are several of us at that level with the 16G with pump fuel and even cat converters. It's generally accepted that ~380whp (DJ or DP) is about the limit of the 16G on pump, so you're about there.
Old Nov 5, 2004 | 08:24 AM
Fourdoor's Avatar
I don't think he personally had seen numbers like that yet on pump gas out of an EVO. He is still getting used to how much better the EVO turbo is stock over the Subaru stock turbo's
Keith
Old Nov 5, 2004 | 08:30 AM
Ted B's Avatar
I'd like to see a chart of your A/F if possible.
Old Nov 7, 2004 | 03:09 PM
Fourdoor's Avatar
I don't have an A/F ratio charte, since I have it all in my AEM EMS data logs. I was running 11:1 all the way from onset of boost till end of pull.
Here is a charte of my new 94 octane vs stock on 94 octane
Keith
Attached Thumbnails Stock compressor, 94 octane 375 HP-stock-vs-now-94-octane.jpg
Old Nov 7, 2004 | 10:14 PM
Zeus's Avatar
Very nice
Old Nov 8, 2004 | 12:43 AM
Blitzbaster02's Avatar
nice #'s. What mods?
Old Nov 8, 2004 | 12:45 AM
JDM-Spec.com's Avatar
Look forward to getting something like this out of my MR while tuning it with Greddy e-Manegment, while using HKS cams.....
Old Nov 8, 2004 | 10:59 AM
Fourdoor's Avatar
Buschur Racing stage 4 plus the AEM EMS, SSAutochrome header and O2 housing, Magnus sheet metal intake manifold, and the upgraded hotside on the turbo.
Keith
Old Nov 8, 2004 | 03:51 PM
GottaGoFaster's Avatar
Keith
Why does it say Fly Wheel Power up top?
Old Nov 8, 2004 | 05:07 PM
Graysilvia's Avatar
Feel like posting your .Cal file?
Old Nov 8, 2004 | 05:30 PM
Fourdoor's Avatar
See at the bottom right hand side where it says "tcf 1.00"? That is a fudge factor you can enter to give you an estimate of flywheel HP based on the wheel HP. When that factor is 1.00 it equals the wheel HP
Keith
PS: A dynapack AWD dyno reads virtually the same as an AWD dynojet without a fudge factor put in. That is one of the reasons I included my stock plot on that graph
Old Nov 9, 2004 | 08:14 AM
GOKOU's Avatar
Great numbers! Anyone care to explain what the 10.5 is and what it does along with titanium exhaust wheel and shaft. What were the benefits seen? cost?
Old Nov 9, 2004 | 08:27 AM
Ted B's Avatar
10.5 refers to the area of the hotside housing. The factory housing is 9.8cm2. The upgraded hotside (standard on new EVO MRs) is 10.5cm2. This doesn't really change the power potential of the turbo, but gives a bit of a boost power until the compressor wheel runs out of steam.
The larger housing tends to delay spool time just a bit due to the slightly reduced exhaust gas velocity, but the Ti internals weigh less than the Inconel internals of the factory turbo, and thus restores the stock spool characteristics.
The 10.5 hotside housing mod is cheap by itself. Add the Ti internals and the price jumps a bit.
David Buschur
Evo X Dyno Results
32
May 13, 2010 03:56 PM
Fourdoor
Nov 14, 2009 03:47 PM
PERRIN_JOHN
24
Apr 23, 2009 11:01 AM
David Buschur
161
Aug 23, 2007 09:22 PM
David Buschur
28
Oct 6, 2003 09:20 AM
