Octane boosters good?
Old Nov 7, 2004 | 12:15 PM
TurboWill's Avatar
Originally Posted by 4-BNGR
Take it back! Go to your local paint store and buy a gallon of Toluene ($9bucks). Then PM me for the formulas or do a seach onthe forum for a Toulene calculator. Do not exceed 30% Toluene to 70% pump gas. This stuff is pain thinner and a component of regular pump gas. I run it all the time and the car w/o it is like night and day.
4-BNGR
Hey thanks alot. I'll head up to my local paint shop tomorow.
I'll PM you when I get it.
__________________
Rally Red EVOVIII
Old Nov 7, 2004 | 01:20 PM
plokivos's Avatar
I used the stp brand but felt like it was wasting my money.
Where do you get Torco? I don't care about the cat, since I don't have one. lol.
Long as it doesn't blow my engine up or leave it gunky.
Old Nov 7, 2004 | 01:46 PM
machron1's Avatar
I get 5 gallon cans of Toluene from the Chevron petrochemical company called TARR here in Portland. It's $30/can, so $6/gal. You spent $8 for your "NOS" octane booster.
So, let's do a comparison, starting with a mix of each booster with 92 octane premium:
NOS "off road formula" claims gains anywhere from 4-7 octane "points". So, the BEST you could expect (which is probably not what you really get, especially when mixing with premium fuel) would be 92.7 octane.
Now, spending that same money on Toluene, which is 114 octane, you would get 1.33 gallons of Toluene. Your tank holds 14 gallons total.
So, ((92octane * 12.66gal) + (114octane * 1.33gal) / 14gal ) = 94.00 octane. If we were to rate it by the "octane point" system, you would get about 20 octane points increase, compared to the maximum 7 octane points of the "NOS" booster. Toluene would be more than twice as effective at the same price, and wouldn't have lead substitute in it.
Old Nov 7, 2004 | 01:49 PM
plokivos's Avatar
is this like the paint thinner or the paint thinner? I don't wanna run lean and blow something up.
The race gas is how much again? Isn't it $6 a gallon at 103 octane?
Old Nov 7, 2004 | 02:47 PM
Evo442's Avatar
Another option is Xylene instead of toluene. xylene is alittle cheaper where I get it and has an octane rating of 117 instead of 114 for toluene. both are simply hydrocarbons. Toluene is added by the gas companies to increase the octane of the fuel we buy at the pump
Old Nov 7, 2004 | 04:45 PM
4-BNGR's Avatar
__________________
Rally Red EVOVIII
Good to hear it I'll teach you how to calculate octane and toluene/gas percentages. Very easy to pick up.
You will also need to following things before you start making cocktails if you don't have em already:
1) Rubber gloves ($2 at Walmart)
2) Funnel ($1 at Walmart)
3) 1 gal plastic gas can ($2 at Walmart)
No, i don't wotk for Walmart
Handle this stuff w/ respect. It (like gasoline) is a poison, is flammable, etc. Avoid skin contact (gloves), avoid inhallation (do it outside or in a well ventilated garage), and avid spilling on your car (it is a paint thinner afterall). You clear coat will save you a couple of times but after a while your paint will fade, etc.. Just make sure that the cap on your gas can is fastened tightly..
4-BNGR
Old Nov 7, 2004 | 04:55 PM
90GSX-03EVO's Avatar
There's been a lot of people on here that have used octane "boosters" and had some pretty nasty results. O2 sensors screwing up, cat-converters dying, even fuel injectors getting clogged.
I have been at 2 Mitsu dealerships getting my car serviced when, at each one, there was another Evo in at the same time. #1 was in Mobile, AL and the car had clogged fuel injectors. They said it was from running octane boosters that contained MMT. #2 was in Virginia Beach, VA and they said the O2 sensor was gone because of octane boosters that contain MMT. Lots of others on these boards have complained about them. I won't touch the stuff. I never have used them because I think they are a stupid idea, personally. It's almost like that "engine rebuild in a can" stuff they sell.
Be careful of the things they sell like that. It might say that it is safe for cat-converters, O2 sensors, and all that. But I'm sure they're really not that worried about people taking them to court over it. Even if they did, I'm sure they would say that you just overconcentrated it or something. Have fun and don't screw over your motor with this garbage. Stick with something that is proven to work and a lot safer, like Toluene.
Old Nov 7, 2004 | 08:51 PM
Evo442's Avatar
Originally Posted by Spec C
Torco race fuel concentrate is good stuff.. They have both unleded and ledded, 32oz can turn a tank of 93 into a tank of 104+... When i go racing on my pump gas map i usually add like 12oz or so just as a buffer for knock..
D-
torco's website doesn't say much. can you tell us how it works, how much it costs, etc?
any dyno graphs comparing before and after torco?
Harsh476
Jan 9, 2016 09:58 AM
Gsxtremedsm
May 9, 2007 04:28 AM
ItalianEvo
39
Jun 21, 2006 11:28 AM
RallyRedRSIX
Apr 23, 2006 07:50 AM
reTro
Oct 13, 2004 08:59 AM
