View Poll Results: RPM raise between shifts?
YES --- Modified ECM (includes all after market EMS and piggyback and flash ECU)
93
30.49%
YES --- Modified clutch (all aftermarket clutch)
71
23.28%
YES --- Modifed MAF (convert to speed density)
18
5.90%
YES --- Modifed BOV (all after market BOV now or tried before)
91
29.84%
Yes --- All stock on above parts
95
31.15%
Not at all (includes stock or modified)
76
24.92%
Multiple Choice Poll. Voters: 305. You may not vote on this poll
Old Dec 10, 2004 | 04:46 PM
  #181
titaniumkingpin's Avatar
come on, someone must find a fix.
Old Dec 13, 2004 | 06:33 PM
  #182
THX1138's Avatar
I posted a similar quiery previously. In our Aus Spec cars it tend to start from around 4500rpm.
I got onto MMA (Mitsu Motors Aust) and this is what they said:
"I have checked out our database and found that from EVO8MR we have revised
the program to reduce shift / deceleration shock to improved the total driveability.
Therefore, subject condition is correct and worked well in accordance with
our ECU program."
According to them it is tuned into the car. Still I am not happy with it. Have driven the car for 4500kms.
It was worse ealier on, but as the car loosened up it became better. That siad it is still there.
My big concern is clucth wear, as changing down gear from high revs is going to hurt the thing.
Old Dec 14, 2004 | 02:22 PM
  #183
Borren's Avatar
Hello.
So far by testing some aspects it really looks like the engine gets to much fuel above 5000rpm and the raise is air/fuel beeing burned up.
either that or some ecu programmer had a bad day..
its not related to cluth or the trottle spring as i have noticed..
ill shed more light on the subject as we test things out..
/Anders
Old Dec 14, 2004 | 02:33 PM
  #184
v8killer's Avatar
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ATTENTION POSSIBLE FIX !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Here is an update from my post from before. Vtech8tr unplugged the sensor behind the clutch pedal. This sensor ,senses, when the clutch is depressed. It's a safety feature. For instance without the sensor being plugged in, the vehicle will start without pressing in the clutch! Be Careful!!!!!
The good news is that I have not had this RPM rise since unpluging the sensor. It's been about 2 1/2 weeks!!!!!! I am not saying that the problem is solved, but we think it does have something to do with this sensor. This sensor is in a very vulnerable area and can easliy get damaged. The bracket mine was attatched to was bent... Being so easliy damaged this could explain why even the new Evo's are having this problem. maybe some of these sensors are faulty from the factory. I will continue to report on this issue, and for now I have not replaced or reattatched the sensor.
Maybe my buddy vtech8tr can chime in on the exact location of this sensor.
Old Dec 14, 2004 | 03:18 PM
  #185
Borren's Avatar
Well thats easy enough to test, once i have some more info ill post it.
Old Dec 14, 2004 | 03:39 PM
  #186
Smile
Please post updates!!!
pictures of this sensor would be nice.
I SEE LIGHT!!!
Old Dec 14, 2004 | 03:51 PM
  #187
VTECH8TR's Avatar
I SEE LIGHT!!!
Its on the clutch pedal. Jsut get a mag lite and crawl under their and unplug it and drive around to see if you still have the same problem.
Old Dec 14, 2004 | 04:28 PM
  #188
v8killer's Avatar
it's kind of a ***** to take a pic of. You'll see it if look down there, it will take you all of about 20-25 seconds!!!!!!
Old Dec 14, 2004 | 05:05 PM
  #189
Borren's Avatar
Nope. didnt work. besides for your info the car starts without clutch without pulling that cable
atleast mine does..
/A
Old Dec 14, 2004 | 05:09 PM
  #190
v8killer's Avatar
You already took it off and drove it and still go the RPM raise? You might have another problem since your car should not start without depressing the clutch!!!!!!!!
Old Dec 14, 2004 | 05:35 PM
  #191
ModenaTwinTurbo's Avatar
can someone post wiring schematics of this plug? i highly doubt that theres an input for it on the ecu. but i'd like to know for sure if i am wrong.
Ed-
Old Dec 14, 2004 | 05:56 PM
  #192
VTECH8TR's Avatar
Ditto.
Old Dec 14, 2004 | 11:15 PM
  #193
(fingers crossed)
Old Dec 15, 2004 | 06:29 AM
  #194
Borren's Avatar
Smile
Why wold i have a problem? no car as i know sold in sweden has this as a requirement
Its never been working like that on a evo in sweden thats for sure.
Old Dec 15, 2004 | 06:40 AM
  #195
THX1138's Avatar
I agree. Our Aus spec cars do not need to have the clutch depressed to start either. MMM, maybe a new thought process here
