service engine soon = loss of performance
Old Dec 24, 2004 | 05:11 PM
Jakeg97's Avatar
its my understanding of this ses light that if and when it comes on, the ecu will go into a safe mode that decreases your cars performance. of couse this is to not to hurt the engine. what go you guys think?
Old Dec 24, 2004 | 06:47 PM
plokivos's Avatar
it depends on the warning. If it's lack of cat, it's just visual warning where it's just letting you know, like seatbelt warning light.
But when you have something like fuel/ air/ boost CEL, then it'll goto safe mode, as it'll go into safe mixture of fuel/ air/ and boost.
ECU is constantly monitoring all the engine activities and that's all it does.
When your CEL light blinks, you're in trouble. The ECU will start cutting engine functions all together.
Old Dec 24, 2004 | 07:49 PM
Jakeg97's Avatar
i thought it was any time this light came on that the ecu would go into safe mode.
doesnt matter what the problem. i didnt know that it could selectively choose safe mode regardless if the light has come on.
Old Dec 25, 2004 | 10:03 PM
Jakeg97's Avatar
anybody else have a comment on the service engine soon light?
Old Dec 25, 2004 | 10:10 PM
johnnysixer's Avatar
I haven't noticed a decrease in power when I get a cel from running catless. Mine goes on and off periodically. I gotta get that fixed.
Old Dec 25, 2004 | 10:11 PM
TEXSRT4's Avatar
i dont know, but i do want to say this:
NEVER DRIVE WHEN YOUR CHECK ENGINE LIGHT IS FLASHING!!!!!! NEVER NEVER NEVER. its basically saying "im going to go *BOOM*
Old Dec 30, 2004 | 11:32 PM
Jakeg97's Avatar
well i got a ses light now - thats not caused from o2 sensor
my car is definitely in safe mode. car wont go past 4500 rpms and gas milage has dropped to like 10 miles a gallon
Old Dec 31, 2004 | 12:03 AM
plokivos's Avatar
if your rpm isnt going past 4500 rpm, that means your boost is cut because your injectors maybe clogged....
or your fuel is cut, because something is wrong with your car. I would go see a dealer, because I think you're on a safe mode.
Does your car cut off like a fuel cut?
Old Dec 31, 2004 | 12:24 AM
erockOZ's Avatar
From: Northwest Chicago Subs - Serving in Korea till 09
I had injector issues a while back and had the same problem you discripe. Also, if i hit around 80 while in that mode, the gas tank would just drain. It's all so you don't blow up your engine. If you have lots of mods and want to avoid the dealer till you have to, see any car shop and just have them run diagnostics. cost like 100 bucks most places.
Mine was cause when a friend of mine installed the rrm piggyback, they broke the wire to the injectors and the ecu read off bad injector controll pin and gave the number for needing a new ecu. Just incase you get the same thing. All i needed to do was run a new wire from the ecu to my injector control unit ( or whatever you want to call that part). Good luck
Old Jan 2, 2005 | 09:52 AM
Jakeg97's Avatar
its like an rpm limiter , will flutter at 4500
sometimes i will get the fuel cut-out, depends on how i drive it
Old Jan 17, 2005 | 06:09 PM
Jakeg97's Avatar
here is some pics of my spark plugs after 200 miles of safe mode @ 5mpg
Old Jan 17, 2005 | 06:18 PM
tokeone's Avatar
i thought those were your plugs after 3500 miles from the spark plug thread?
Old Jan 17, 2005 | 06:21 PM
Jakeg97's Avatar
sorry about that it was the wrong picture. the 3500 mile spark plug pic has been changed from the spark plug thread
kylefowlie
Feb 22, 2016 11:54 PM
dangelo2jz
10
Jan 27, 2007 04:27 PM
af-performance
Evo 'For Sale' Exterior Styling
Sep 22, 2006 11:39 AM
k270kmh
50
Aug 28, 2005 11:03 AM
evoWALO
Mar 31, 2005 03:35 PM
