Thermostat Install
Old Jan 7, 2005 | 05:05 AM
justchil's Avatar
Question Thermostat Install
Has anyone installed a thermostat on their evo8? I've only found 2 thread about this and the instructions are extremely vague.
I've got the manual here:
http://www.justchil.net/gallery/evo_engine/thermostat
My question is: Do you HAVE to drain the coolant to change the thermostat? I let the car cool down over night and when I started coolant started to leak
Anyone have tips on which coolant to buy? I'm sure I can search and get the right mixture for my application.
Old Jan 7, 2005 | 05:10 AM
Event-Horizon's Avatar
well, you'll prob have to at least drain the top of the motor and the rad to bring it down to the Thermostat level. You might want to ask a mitsu parts dealer if there is a gasket in that area or if it requires some sort of sealer.
As for coolant, Prestone makes an "All makes All Models" 50/50 antifreeze which works great and is premixed. Depending on how many miles you have you may just want to go ahead and flush the entire coolant system.
Old Jan 7, 2005 | 05:43 AM
justchil's Avatar
I think you do need to apply some sealant.. I'm @ 25k miles so I may order some new hoses and just flush the entire system.
Here is the manual on doing this:
Old Jan 10, 2005 | 12:48 PM
justchil's Avatar
Well I've got it installed now.. still paranoid about coolant leaks and such. Car seems to be running a little cooler
Old Jan 10, 2005 | 01:06 PM
badlooser's Avatar
put mine in and it does run cooler .
gilevo7
May 20, 2017 10:55 PM
mindoftw
Feb 20, 2016 06:09 PM
EGbeater
24
Aug 10, 2015 09:10 PM
EGbeater
34
Mar 1, 2015 09:52 PM
evoxsi
12
Oct 16, 2010 04:26 AM
