How hard is it to install Transfer case??
Old Jan 10, 2005 | 05:09 PM
racerferrari's Avatar
well i purchased a used transfer case and the dealer wants $425 to put it in......i could do it myself but i'm a little worried....some people i've heard have issues with lining it up and gaskets...stuff like that.....i don't want to blow out another one....anyways....any helpful advice at what i would have to watch out for....anything will help...i don't want to have to dish out another $425...thanks...wayne....www.pulpracing.com
Old Jan 10, 2005 | 05:25 PM
plokivos's Avatar
if you haven't done it yet, I don't recommend you do it. This is 2 peoples job.
I would say $425 is fairely cheap.
anyway, good luck.
Old Jan 10, 2005 | 06:03 PM
jj_008's Avatar
It shouldn't be that bad. A lot easier then replacing a clutch. There shouldn't be a problem w/ gaskets if you don't use pry bars on them. Lining up the transfer case wasn't a big deal; at least when I did it.
Make sure when you knock the splined axle through the transfer case and tranny that you don't break the c-clip.
Old Jan 10, 2005 | 06:18 PM
plokivos's Avatar
you also need that special puller to pull the t-case off.
Old Jan 10, 2005 | 06:22 PM
jj_008's Avatar
Nope. You need a slide hammer to take out the splined axle though.
Old Jan 10, 2005 | 06:37 PM
sleet's Avatar
If your worried then don't do it, its going to cost you way more than the price to install it just to fix it.
Old Jan 10, 2005 | 06:55 PM
plokivos's Avatar
yeh, slide hammer, that's the tool. I just couldn't think of it.
Not many people have slide hammer in their garage you know.
eddy5201314
Apr 21, 2017 06:34 PM
slevo
Feb 26, 2014 11:15 PM
duranvw
Jul 29, 2012 05:17 AM
Booztd 3
11
May 23, 2010 11:13 PM
ItsStockOfficer
Mar 24, 2004 07:20 AM
