HelP!!! WhaT HapPeneD???
Old Jan 11, 2005 | 12:27 AM
ThEyElLoWoNe's Avatar
After a night of driving here and there, and not racing around, I decide to spool up the turbo a bit...and when i stepped on it in 2nd, the turbo started to spool up and then all of the sudden lost power!!!! Now, i have no idea what happened, it may be something that just happens! Can someone please help me out!! Oh yea, and after it happened once i did it again and it happened again, and even the third time!!!
Old Jan 11, 2005 | 12:31 AM
simevo's Avatar
Check your ic hoses for leaks. Look near the throttle body area first and tighten the hose clamps. After that check rest of the ic pipes.
Old Jan 11, 2005 | 12:57 AM
okaY!! Thank you for your response, i will do that!!! Do you have a clue to why this would happen??
Old Jan 11, 2005 | 01:01 AM
simevo's Avatar
Many people have had their boost hoses pop off. Evo's boost around 19psi and can spike above that causing the hoses to just pop off or leak in your case. Just tighten the hose clamps and see if it that was the problem.
Old Jan 11, 2005 | 01:38 AM
striderx88's Avatar
where is the boost hoses any pics??
Old Jan 11, 2005 | 01:40 AM
Silvercar's Avatar
Look on the intake manifold..
Old Jan 11, 2005 | 02:05 AM
ap-evo83's Avatar
From: RAMAR village, pampanga PHILIPPINES, Temecula, CA
sounds like a leak alright.
Old Jan 11, 2005 | 01:08 PM
okay, so my friend (the mechanic) will be gone all week, and i dont know as much about cars as others so could someone help me out to where i could find the hoses?!?!? I looked, and i have no idea what im doin!! so if anyone has pics or could tell me like (on the right of the turbo) or something that would be a big help!! sorry for being such a newbie about this! its just that .....well im a newbie at all this stuff!!
Old Jan 11, 2005 | 01:49 PM
bump! anyone?? i dont want to drive my car like this
Old Jan 11, 2005 | 02:22 PM
ok so i think i fixed it, one of the hoses was falling off!! (you were right) and i also checked all of the others and it seems to be fine, but now i only have a loss of power in 3rd at about 4500 rpm's! why is that, is it the same problem, or do i have a bigger problem??
Old Jan 11, 2005 | 02:35 PM
marksae's Avatar
You fixed the major leak, and probably still have some minor leaks. The minor leaks is probably what's causing the loss in power. You should probably have a mechanic check all the intercooler pipe connections for loose clamps and hoses. Or you can climb under your car, take off the undertray, and tighten all the lower ic pipe hoses.
the lambo kille
Jul 16, 2012 07:43 AM
robertg
Oct 5, 2009 01:53 PM
bbyevo8u
Nov 6, 2005 07:25 AM
heSOshAdy
Aug 23, 2005 11:49 AM
