Any damage to stock valvetrain
Old Feb 3, 2005 | 07:45 AM
  #91
ogvw's Avatar
the 272's have the same lift as the 264's - same problem
Old Feb 3, 2005 | 08:01 AM
  #92
mttam510's Avatar
I read it as there were no problems with their RS revving safely to 7500. Again, there is no way in hell that this interference would be noticed unless you install a "flow-bench" spring that allows you to see what is happening behind the shroud of a compressed spring. BTW the 264 and 272 have the same lift 10.8 INT 10.2 EX, so there is no difference between the two cams 264/272 with what we are talking about here....both cams lift the valve the same ammount, the duration is the difference.
Old Feb 3, 2005 | 08:29 AM
  #93
NYREDEVO's Avatar
Stupid question...I am really not familar with a flow-bench spring so bear with me... How does that work? Is it possible that you are only seeing the wear & contact b/c the flow bench spring itself? Im just trying to understand why you are the only one getting these results.
Old Feb 3, 2005 | 09:02 AM
  #94
Ted B's Avatar
Originally Posted by ogvw
the 272's have even more lift than the 264's - exacerbating the problem
FWIW, the 264s and the 272s have exactly the same lift.
Old Feb 3, 2005 | 09:04 AM
  #95
ogvw's Avatar
^ correct - fixed my post Thanks!
Old Feb 3, 2005 | 09:06 AM
  #96
ogvw's Avatar
The "flow bench spring" is a low pressure spring fitted to the valvetrain during flowbench testing to facilitate moving the valve by hand. Its just a spring to hold the keepers/retainer together really....
Old Feb 3, 2005 | 09:55 AM
  #97
NYREDEVO's Avatar
So could that effect the wear pattern? You did not really answer that part of my question?
Old Feb 3, 2005 | 10:03 AM
  #98
mttam510's Avatar
Please re-read the above post.....it answers the question, it is just used to hold the syatem (keepers/valve/retainer together). I guess the reason that we are the ONLY ones to find this is because we actually did our homework, it is plain as day. And as we said before, unless you actually looked at the system with the "real world" valve spring removed. I guess nobody bothered to look for it.
Old Feb 3, 2005 | 11:14 AM
  #99
ogvw's Avatar
No - the spring does not change the travel of the retainer/valve assembly - it just allows us to look at what is happening under the retainer (normally hidden by the OEM spring coils).
Old Feb 3, 2005 | 11:22 AM
  #100
jeremy@matrix's Avatar
Damn, you guys at Revolver certainly have your pants on straight. No Kris-Kross backward pants action like the other guys. Glad someone is doing this much needed homework. Very nice to have an industry leader like you guys.
We are definitely supporting Revolver cams from now on!
Best regards,
Jeremy
Old Feb 3, 2005 | 01:08 PM
  #101
fatbastard's Avatar
Originally Posted by davidbuschur
The HKS 272's do NOT come in contact with the valve seal, I just went back and checked a head.
David Buschur
www.buschurracing.com
just checked... really?
Old Feb 3, 2005 | 06:33 PM
  #102
freedom's Avatar
What am I missing?
CAMSHAFTS
HKS high performance camshafts are CAD designed to optimize torque and horsepower over the widest possible power band. Each camshaft application is offered in multiple profiles, each with their own duration and lift characteristics to suit various levels of tuning. Lower profiles offer substantial gains in power and a broad useable power band throughout the rpm range with little compromise in driveability. High profiles offer greater increases in power, but are tailored for higher RPM range and racing. Increases performance from the HKS camshafts are achieved by: 1) Increasing the duration of valve opening, which increases power at higher RPM, and 2) Increasing lift, which raises torque. All HKS camshafts are made from billets of high nickel content iron alloy, not reground stock units, so they equal or exceed OEM units they are designed to replace. The camshafts are direct replacements and are designed to be compatible with factory followers and valve springs. HKS also offers high performance valve spring sets for limited applications that benefit from stiffer springs when using higher profile HKS camshafts.
Old Feb 3, 2005 | 07:14 PM
  #103
Jorge T's Avatar
What I don't understand is like shown in picture 2, it starts making contact at that cam position how come stock cam does not also hit?
Old Feb 3, 2005 | 08:13 PM
  #104
mttam510's Avatar
That is because the stock cam does not have as much lift (the amount the valve is opened) as the HKS units
Old Feb 4, 2005 | 05:58 AM
  #105
Grog's Avatar
Stock Cams Lift:
Int - 10.0mm
Exh - 9.5mm
HKS Cams Lift:
Int - 10.8mm
Exh - 10.2mm
You're talking about a difference of only 0.7-0.8mm for each.
So the cam lift difference is less than a millimeter. But in the pictures the seal is being contacted well before max lift and is significantly contacted at max.
Doesn't make sense to me. If the stock cam has plenty of clearance, why would an extra 0.8mm of lift create the interference created in the third photo?
