Turbo Upgrade Kit...
Old Jan 31, 2005 | 12:26 PM
  #31
evo81's Avatar
Originally Posted by fre
I have the same kit compressor is .7 a/r Maybe with cams I will see better spool up. It isn't bad, but I just am not a launcher on the street. I can waste 99% of whats out there without launching anyway.
i hope it's not to laggy on the streets.i'm looking hard at the gt35r kit,and i need it to be a vette/viper killer on the streets
Old Jan 31, 2005 | 12:54 PM
  #32
fre's Avatar
fre
Well unless you are willing to launch it, they will probably beat you on the street. From a roll you will stay with them as long as you run decent boost (~23psi). That is the vette. The viper is another story. I wouldn't expect to hang with a stock 11 second vehicle unless I was running ~ 27psi or so on race fuel.
Old Jan 31, 2005 | 01:52 PM
  #33
umiami80's Avatar
Hell no, the viper Traps @ 122MPH, Easilly done with a GT35R on pump, hell even a 50Trim if tuned properly. If you launch properly, you get VERY fast spoolup on a BIG turbo.
Old Jan 31, 2005 | 02:21 PM
  #34
TalonRcR's Avatar
Thumbs up
Originally Posted by Evo8kid
i as well will vouch for it....ive heard its the best turbo kit u can buy for the evo...actually i might be purchasing it in the spring ...still not sure
Best looking one I've seen.
Chris
Old Jan 31, 2005 | 02:53 PM
  #35
2MANYCARS's Avatar
I want a 20G turbo as my turbo upgrade for this year.
Old Feb 1, 2005 | 06:28 AM
  #36
fre's Avatar
fre
How do you know this, do you own one of these turbos? I sure can't get 122mph on pump gas at all, let alone easily. More like 112 on pump. Maybe 114-115 here at sea level.
Old Feb 1, 2005 | 06:32 AM
  #37
badlooser's Avatar
stock turbo evos with pump gas trap at 113mph. 120mph with a bigger turbo is no problem.
Old Feb 1, 2005 | 06:37 AM
  #38
Az3ar's Avatar
Originally Posted by housedj
what about the Norris Designs kits? their stage 3 kit looks promising (650-800hp)...
http://www.norrisdesigns.com/
NorrisDesign turbo kit is the ATP stage 3 kit which you can get from atpturbo.com
Old Feb 1, 2005 | 07:05 AM
  #39
fimotorsports's Avatar
with the new water injection kit's from AMS coming out, trapping in the high 120's and low 130's should be very reacheable on pump gas with the 35r kit.
Old Feb 1, 2005 | 07:26 AM
  #40
fre's Avatar
fre
Water injection is not much different than race fuel though...you still have to use something special. How long would a tank of water last? I am curious if it only kicks in when you accelerate hard. If this is true I will definitely be looking into this. I doubt I could get 120s even with race fuel though. I am only spiking to 1.7 or ~ 24psi and dropping to 22 psi or so on race fuel and getting 116. I am sure with water injection/race fuel, cams, and ~ 25psi I might be able to hit the 120 mark though. I doubt I would hit 116mph at the tracks in Phoenix either. I can only seem to hit these high mph at these sea level tracks. I will try Firebird in Phoenix on my way back though.
Old Feb 1, 2005 | 07:37 AM
  #41
NYREDEVO's Avatar
Fre- U might want to check this thread out...its alky but it might help
https://www.evolutionm.net/forums/sh...d.php?t=120030
Old Feb 1, 2005 | 04:54 PM
  #42
housedj's Avatar
Buschur racing is running 11.23 @ 124 on a stock turbo!!!!!!!!!!!!!!!!!
Old Feb 1, 2005 | 05:09 PM
  #43
spoolingEVOx's Avatar
how do you guys suppose Buschur's 20G Twin Scroll Upgrade would compare to the smaller of AMS's turbo kits- the GT3071R; in terms of longevity, reliability, and performance?
are they about equal, with Buschur's being the longer lasting since it retains the factory twin scroll, water cooled turbo?
i am practically sold on the Buschur, i'm just curious. i'm not looking for a dyno queen or a dragster; just your every day quick spooling, high output road racer.
Old Feb 1, 2005 | 05:38 PM
  #44
umiami80's Avatar
I get 112 MPH or faster on my STOCK Turbo, get some tuning buddy, there is something wrong with your car.
Old Feb 1, 2005 | 07:18 PM
  #45
fre's Avatar
fre
Do you have cams? There is no way my car would have done better than about 108-110 on the stock turbo. I was only getting 107 at the track when I ran. Usually 105 though. Trust me, I have no doubts I need another reflash. I can probably get away with more timing than I am running. Oh and I need to adjust my AF with my afc for race fuel, because it always runs richer with higher octane. And as far as Burschur running that 11.23 on the stock turbo.....how many people are in the 11s on the stock turbo? There is a list and I bet most are larger turbos on that list. It CAN be done, but certainly isn't easy.
