Are reflashes worth it?
Old Jan 25, 2005 | 01:08 PM
evodrifter's Avatar
I have a SAFC and im pushing just about 275 to the wheels with everything i have done, no problems and it doesnt run lean, I was wondering if reflashes are worth the money. Most of the places i look at for the decent tunes they are around 300-400 for a full reflash. Any help would be great full
Old Jan 25, 2005 | 02:49 PM
GBEvo's Avatar
I also have an SAFC and was wondering the same thing. From reading some of David Bushcur's posts I'm guessing they are. From working with Al from Dynoflash, I think he is switching from the SAFC to the flash methods. Besides, it might be worth it just so you don't have the SAFC in when you take it to the dealer. I've heard they don't look to highly at it and they normally can't detect a flash unless they are looking for one. I'm eventually going to get a flash after my cams go in, but I'll probably keep the SAFC for some rough adjustments when I add more mods until I can get reflashed again.
Old Jan 25, 2005 | 02:58 PM
GinuwineEvo8's Avatar
Yeah I'd say its worth it ... Plus lets say you flash for your current mods .. Then you can use the SAFC-II to be tuned for a higher octane gas ... (race gas/trick) ...
Old Jan 25, 2005 | 03:02 PM
evo542's Avatar
yes, because they're invisible to the dealer!!(except the 05 models)
Old Jan 25, 2005 | 03:07 PM
KILTERMAN's Avatar
doesnt the reflash screw up the immobilizer? I thought I read somewhere that the Immobilizer is disabled when doing a reflash
Old Jan 25, 2005 | 03:21 PM
evo_whiplash's Avatar
I though stand alone was the only one that did.
Old Jan 25, 2005 | 03:22 PM
nine4surfah's Avatar
I read a thread about the samething a while back. This particular person reflashed the cpu and unfortunately the engine imobilizer was malfunctioning. If I remember correctly the person sent his evo to the dealer to have it fixed and had to jump though a bunc of red tape in order to do so.
Old Jan 25, 2005 | 03:49 PM
KILTERMAN's Avatar
hmm wonder if dynoflash or any other flasher can clear this up
Old Jan 25, 2005 | 04:02 PM
hotrod2448's Avatar
If that is the thread I'm thinking of the problem with the immoblizer came from that person switching ECU's. He traded his ECU for one that had been reflashed and was taking it in to the dealership to have the key programmed to work with that ECU. Thats how the dealership knew something was up. As long as it's your ECU you get flashed it should not affect the immobilizer.
Yes, the reflash is worth it. Even with an S-AFC and boost controller you still have no ignition timing control. Plus the factory ECU controls boost better than most boost controllers.
Old Jan 25, 2005 | 04:24 PM
DynoFlash's Avatar
The proper way to handle a reflash is to have your original ecu from YOUR car flashed.
I have done well over a 1,000 evo flashes without incident in this manner.
If you change the ecu - this is when you eed to have the new ecu programed by the dealer to match your imobilzer and key codes which takes them abot 15 minutes and should cost avbout $50 - $75.
Old Jan 25, 2005 | 04:28 PM
hotrod2448's Avatar
That's what I was saying the guy traded his stock ECU for one that had been flashed.
Old Jan 25, 2005 | 04:30 PM
I believe that is the same thread...didnt realize that the person was using two different ECU's Thanks for clearing this up!
Old Jan 25, 2005 | 04:31 PM
DynoFlash's Avatar
The ability to seperately control a/f and ign timing with the flash gives you a much smoother tune with loads more low end tq.
With the SAFC you can make decent peak power but the adjustment of the a/f ratio requires you to attentuate the maf sensor signal which results in running into low boost zones in the ignition timing map under full boost which are way to adavnced ign timing. Lean a/f and too much timing makes trhe ecu pull out timing in an uneven manner and leaves you with the classic rough bumpy afc power band.
The flash gives you a much greater control and a factory quality smooth tune.
Old Jan 25, 2005 | 04:32 PM
hotrod2448's Avatar
I'm glad my wealth of useless knowledge isn't totally useless.
Old Jan 25, 2005 | 04:35 PM
BaLListic_EVO's Avatar
yeah its worth it just the base flash made me pretty happy.... and Al is a good guy to deal with
