SES Random Misfire Fix
Old Feb 2, 2005 | 04:59 PM
  #31
bryans2k's Avatar
Here is the ECU pin out by Road Race Engineering.
http://www.roadraceengineering.com/e...-ecuwiring.hth
The PIN 85 Barometric Pressure Sensor Signal.
bryan
Old Feb 2, 2005 | 05:11 PM
  #32
EVOTEXAS's Avatar
So basically this mod warrants a reflash.
Old Feb 2, 2005 | 10:20 PM
  #33
USP45's Avatar
If the 0300 is thrown due to the camshaft position sensor and the crankshaft position sensor not seeing eye to eye, then every single car out there with cam gears that are set to anything other then a stock setting should throw the code correct? I do not know one way or another, but if this is how the ECU gathers its information to throw the 0300 then it would make sense. For the record, my car had over 7,000 miles with cam gears set anywhere from -1/-4 to -2/-2 with no 0300 codes ever.
Old Feb 2, 2005 | 10:37 PM
  #34
feriosi'evotwin's Avatar
why wouldnt the code clear if their isnt a misfire anymore? mivec were u at?
Old Feb 3, 2005 | 03:55 AM
  #35
Nate's Avatar
No mivec, just varying degrees of random misfire severity. If a car just gets the code, and doesn't misfire, the fix might take care of the SES light. If the car gets the misfiring badly, then it's possible that the fix would get the SES light to go out, but more than likely would just take care of the misfire.
Old Mar 2, 2005 | 01:22 PM
  #36
Zampolit's Avatar
I don't know why but I haven't had the misfire since the gas around here stopped puting ethanol in the gas as of Jan 31st... seems strangly coincidental to me.
Old Apr 3, 2005 | 07:23 PM
  #37
highmileage's Avatar
I have had my car reflashed FIVE (yes, FIVE) times at the dealer for this. The last two, it came and and the car did the normal shuddering on the way HOME from the service appointment !
Not happy.
Old Apr 3, 2005 | 07:47 PM
  #38
KZEVO's Avatar
yours might be a coincidence. I changed from mobil to amoco and didn't help.
Old Apr 3, 2005 | 08:40 PM
  #39
KazzEvo8's Avatar
Rather interesting that this thread died - must not be an easy fix, eh?
Old Apr 5, 2005 | 01:34 PM
  #40
bryans2k's Avatar
It is the exact fix that I listed. If you cut the Baro wire you'll see that your check engine light on the p0300 code will disappear and a baro will appear. If you splice in a potentiometer you can make the check engine light disappear totally. It's basically the solution I will be using until someone comes out with another.
bryan
Old Apr 5, 2005 | 01:42 PM
  #41
boomn29's Avatar
Originally Posted by bryans2k
It is the exact fix that I listed. If you cut the Baro wire you'll see that your check engine light on the p0300 code will disappear and a baro will appear. If you place a splice in a potentiometer you can make the check engine light disappear totally. It's basically the solution I will be using until someone comes out with another.
bryan
What about the vibration that some people get?
Old Apr 5, 2005 | 01:49 PM
  #42
bryans2k's Avatar
That's actually the ECU cutting fuel/spark. I've logged it and it shows the car going completely lean... More like it dropped a cylinder. I'm going to splice in one today and see. I can easily duplicate it so I'll know if it's gone or not.
bryan
Old May 9, 2005 | 05:41 PM
  #43
LancerEVOmann's Avatar
bryan
How did it turn out?
Old May 9, 2005 | 06:36 PM
  #44
rkm625's Avatar
bryan
im confused a lil bit. But does this keep it from misfiring? or just lose the SES light? I'd love to lose the lovely orange glow but I dont want my car still not running right.
Old May 10, 2005 | 05:17 AM
  #45
sir lurks alot's Avatar
bump
jwick76
Lancer Troubleshooting
14
Jun 8, 2021 06:41 AM
Enjoi926
May 31, 2017 06:47 PM
Adzel94
Feb 14, 2015 12:12 PM
tscompusa
Nov 12, 2014 01:30 AM
treager
Aug 27, 2014 11:28 PM
