Intakes
Old Jan 31, 2005 | 12:06 PM
negativeB's Avatar
Originally Posted by xtremeboost69
The HKS is garbage IMO. Mainly cuz the point of a filter is to clean the ait coming into your engine and HKS does this the worst. I'd go with either K&N or the Apex'i intake. Those 2 flow the best and are the best at filtering impurities out of the air.
By the way if ya dont believe me: http://mkiv.com/techarticles/filters_test/2/index.html
they reviewed hks' cheapest intake.
Old Jan 31, 2005 | 12:19 PM
IOevo's Avatar
even if the best HKS filter was 200% better than the one tested... it would still be only half what the apex unit is... im sold...
Old Jan 31, 2005 | 01:05 PM
Evil EV0's Avatar
I've had my Injen intake for about 6 months and I love it. You get the intake with upper IC piping and a loud stock BOV
Old Jan 31, 2005 | 01:08 PM
b18flip's Avatar
injen intake gets my vote
Old Jan 31, 2005 | 01:33 PM
xtremeboost69's Avatar
Former Vendor
The fact of the matter is foam filters dont have the filter capabilities as cotton filters.
Old Jan 31, 2005 | 02:49 PM
NOVA EVO's Avatar
Unless you drive in a very dusty environment all the time, you're not gonna notice much of a difference between the filters as far as dust, but there is a difference in build quality, and the HKS RS is top notch. If the Apexi really trapped all that dust, it has to impact performance. It's always a tradeoff between filtration efficiency and performance, especially after the filter has been used for a while. There is just no way around the laws of physics. Choose the one that looks best to you, because in the end, they are all pretty much the same.
Old Jan 31, 2005 | 07:05 PM
DCD's Avatar
DCD
Does any one have the Apexi intake? Does that make the spool and BOV sound louder as well?
I'm worried about these open air filters as so much heat comes off the engine in the Evo, more than any other car I have owned. Surely a underbonnet open air filter will not be ideal? Especially since the turbo is right there about 20-30 cms off the filter, it must pick up a LOT of hot air?
The reason I ask about the Apexi one, is don't they sell an aluminium box that you can fit around the open air filter?
Old Feb 1, 2005 | 11:02 AM
IOevo's Avatar
apex DOES sell a aluminum isolation box, but its not on their website... i found it at www.hopupracing.com and as of Feb 1st, its on sale for $110. i think its a good idea, but its HUGE... you'll probly have to remove your IC spray tank from the looks of it... thats why i was interested in the APS cold air unit for $229, and the IC spray relocation kit for $189. so for a total of about $460 you'll have a complete cold air set up. i would personally opt to not get the IC spray kit and mount it behind the battery in the back right corner of the engine bay. a big open spot there could accomidate the factory tank and you will still maintain the overflow from the tank. a few well placed zip ties and some clever work will make that setup look nice! plus you will be able to actually SEE the CAI. as for the apex-i filter storing up all kinds of dust, ALL filters hold and store dust. id rather loose 2 whp and not have to worry about the internals of my engine getting all jacked up with debris and other crap that can get up under your hood.
Old Feb 1, 2005 | 04:22 PM
bolsen's Avatar
wow, so much discussion over a filter on a stick
Old Feb 1, 2005 | 04:27 PM
housedj's Avatar
Originally Posted by westchester evo
Aps make an intake that drops into the fender.Nice cold air...........
this cold air unit does not work on any of the 05's.
zbomb's Avatar
i got the arc induction box looks real good under the hood
Old Feb 1, 2005 | 04:32 PM
housedj's Avatar
if money is not an issue, get the HKS Kansai cf airbox. works like stock & lets you run aftermarket filters...
Old Feb 1, 2005 | 04:59 PM
sophic's Avatar
if money is an issue use a paper sac.
Old Feb 1, 2005 | 05:26 PM
DCD's Avatar
DCD
Damn that HKS Kansai gear looks wicked. So will that work in conjunction with say a HKS RS filter kit? DOes anyone know if it will work with the Apexi filter kit?
The ARC induction box I saw a picture of. It looks interesting, does it basically just draw air from under the bonnet still though? It looked like it was a cube, with filters on several sides?
Does anyone know if the Apexi heat shield utilises the stock air feed? Dosn't seem like much point shielding off from hot air if you are not gonna give any cold stuff anyway! Does anyone know if you need to modify anything underbonnet to get install it?
1_DARKANGEL
Aug 26, 2007 06:34 AM
1_DARKANGEL
Aug 22, 2007 08:55 PM
liberty2000rs
AEM EMS
37
Dec 29, 2004 02:38 AM
ZyBeR
30
Jun 24, 2004 12:39 PM
srfsup97
Oct 4, 2002 03:40 AM
