ACT clutch installed, now noise?
Old Feb 16, 2005 | 08:10 PM
ACTman's Avatar
Originally Posted by taylor
I had an ACT HD street clutch installed about 400 miles ago. It feels great, but now the trans. is definately louder that before. I only notice it when i bring the engine up past 3500-4000rpms(in any gear) and let off the throttle. It's not a whining sound, just a loud mechanical rattling type of sound, and the car feels fine otherwise. Is this a normal aftermarket clutch sound or could it be something else?
It sounds like gear rattle by the description. It doesn't sound like the assembly/bearing issue. I am going to take a guess that you also installed an aluminum flywheel. Is that the case? I only say that because we haven't had any complaints about noise and with the reduced weight of an aluminum flywheel the disc springs have a more difficult time dampening out torsional vibrations. These vibrations end up making the gears rattle when not under load, which is an audible noise. They take more of a beating too so a super light flywheel ends up contributing to premature disc center wear/damage. How was my guess?
Neteru
38
Apr 17, 2012 06:08 AM
Don Q
May 8, 2011 08:10 PM
ct9a_mr
May 5, 2008 12:09 PM
smokey
10
Dec 18, 2006 03:22 PM
