My Evo is Stalling...Please Help!!!!!
Old Feb 21, 2005 | 06:30 AM
scherejs's Avatar
it's the intake. many people have the same problems as you. i solved mine through a flash, but like said before another popular option is the hks eids.
Old Feb 21, 2005 | 10:43 AM
ringovero's Avatar
ttt
Old Feb 21, 2005 | 10:50 AM
Widebandphillip's Avatar
It's NOT the intake, I have an intake in the car and i don't even need it tuned for closed loop operation anyway. IT's probably a big vaccum leak or a crappy stock bov. The stock maf is located right in between the turbo and the air filter. There's a honeycomb right after the filter. Right behind it is a small wire you'll see. Just get some rubbing alcohol and some q-tips and gently clean off the wire.
Old Feb 21, 2005 | 10:56 AM
34Turbo's Avatar
I hope you didn't mess up the MAF while installing the intake. Also, check out the BOV.
The first day I got my Evo I got my intake installed and did not have any problems...
Old Mar 28, 2005 | 02:19 AM
black evil evo's Avatar
i have an aem with map conversion and it is stalling again. It did this before and the dealer replaced the iac valve under warranty and it was fixed for about 6 months and there it is again. Stalling. The dealer told me this is a common problem that the valves go out often but i don't see many on here that have been told the same as me. Anyone else had this valve go bad?
FastAzzEvo
May 16, 2017 04:46 AM
alpix715
Aug 30, 2010 03:13 AM
ravnos04
Feb 28, 2010 12:47 PM
klexen
Lancer Troubleshooting
Oct 19, 2006 10:03 AM
players234
Apr 22, 2004 10:25 AM
