MBC equpped: 5th gear WOT sputter
Old Feb 22, 2005 | 08:05 AM
RalliArtEvoVIII's Avatar
i was at WOT in 5th gear with my AMS MBC set at 20psi and the car sputtered air frm what it sounded like, twice. i took it WOT for about 3 seconds, it started sputtering, so i let off, got back on it and sputtered again, then check engine came on. about 30min prior to this happening, i pulled over at a gas station and reseted my ECU cuz my CEL was on due to my test pipe, could this have been my test pipe doing somethin to my car? sounded like BOV but it only did it twice, threw a CEL and no more sputtering. im runnin HKS SSQ vta.
Old Feb 22, 2005 | 08:11 AM
GTKage's Avatar
dyno tuning will help u isolate the problem.
Old Feb 22, 2005 | 09:13 AM
BadazzCR's Avatar
Are you sure your not getting the p0300 missfire code. Because it sounds like you are.
Edit: which spark plugs are you running and what are they gapped to?
Old Feb 22, 2005 | 03:32 PM
Widebandphillip's Avatar
fuel cut, don't worry about it.
Old Feb 22, 2005 | 04:17 PM
AlwaysinBoost's Avatar
I would suggest the P0300 code but that only happens at very light throttle in 5th and you said you were WOT...
did it feel like your engine shut off?? if so thats fuel cut.
Old Feb 22, 2005 | 06:20 PM
no, it didnt feel like my engine shut off, it was like a small small jerk, like the car paused for a second, but it didnt feel like my engine was shutting of or anything for sure. could be p0300, cuz the engine check light came on after, cuz i floored it, it was sputtering(air maybe)?, so i let off, then wot again, sputtered again. then CEL. and i jsut continued to drive on my road trip. so the best way of going about fixing this would be ECU flash correct
Old Feb 22, 2005 | 06:27 PM
MYEVOVIII's Avatar
Fuel cut my friend
Old Feb 22, 2005 | 06:30 PM
jeffm1999's Avatar
same thing has happened to me, except I didn't get a check engine light, I don't have a test pipe though. I would recommend installing a Walbro 255 LPH fuel pump so your injectors can deliver enough fuel at WOT and High boost.
Old Feb 22, 2005 | 06:48 PM
megatron's Avatar
what makes the fuel cutoff occur? maybe there is a possible leak? i just took off my hks rs intake and am using the stock airbox with a dejontool intake pipe, and my car is doing the same thing when im on the freeway and im approaching redline, around 5500-6000 rpms.
Old Feb 22, 2005 | 06:51 PM
ok thts possible, but why would i get fuel cut at 4k rpm?
Old Feb 22, 2005 | 06:54 PM
MYEVOVIII's Avatar
You might wanna contact Turbo trix and talk with them about your tune. I know another Ecu tuner eliminates this from happening so they should be able to help you out.
UT_Evo's Avatar
Check your intercooler hoses, same sorta thing happend to me, in 5th gear, at WOT... one of the hoses was loose, and eventually came ALL the way loose... but maybe it's not that... Boost likes to blow the cheap stock clamps and hoses off easy
megatron's Avatar
hey are you looking for a stock intake pipe? the rubber one? how much would you offer me, would you be interested in my dejontool intake pipe?
Old Feb 22, 2005 | 08:15 PM
EvoVIII_SFL's Avatar
check your boost when you get the fuel cut in 5th, its most likely over 20psi...
If you dont have a tune you have to turn the MBC down if you want to go WOT in 5th.
When I had minimal mods including an MBC and no tune I had the boost set to go max. it could without fuel cut in 1-4 gear, in 5th WOT I would get fuel cut. but awd topend isnt great so I went with more power in the lower gears.
Igaly1021
Nov 7, 2015 05:18 PM
santeller
Mar 4, 2011 05:03 AM
drocksmash
Jan 7, 2011 01:13 AM
silver on black
12
Oct 12, 2009 08:27 PM
ct9a gsr
21
Mar 21, 2005 11:44 AM
