evo 8 sputtering?
Old Dec 25, 2010 | 06:14 PM
drocksmash's Avatar
evo 8 sputtering?
did a pull on the freeway today, down shifted to 4th (tuner told me to downshift if im going to go WOT in 5th)
as i pulled WOT in 4th, the car pulled hard but almost felt like it was stuttering for a second... i freaked out and let off the gas, everything was fine. I then realized my fuel light came on. Could this have caused the sputtering? Car was recently tuned by a local and well respected company. I did not see the cel light come on ( tuner said they set up the knock sensor)
Filled the car up but never was able to do a pull on my way to work, to much traffic. Also, i never broke 100, probably 85-90 or so.
should i be worried?
Old Dec 25, 2010 | 11:37 PM
05VIII's Avatar
no
Old Dec 26, 2010 | 12:10 AM
mlstrdc's Avatar
I just had the exact same issue yesterday. As for being worried... I would have to say yes. My Evo had a 'major fail' today and it all started with the same symptoms. I am in the process of posting it up now (Xmas Evo Fail).
Old Dec 26, 2010 | 12:38 AM
BLK_EvIL's Avatar
just look things over check plug gap and do a boot leak test
Old Dec 26, 2010 | 01:17 AM
yahu's Avatar
Derrick (I forget if that is how your name is spelled as I know a few Dereks), it likely wasn't gas. Our gas light comes on pretty early in general (I suppose that could be different from one to the next). IIRC, you have a walbro, right? So that shouldn't be an issue unless your filter maybe has some issues.
Without more info or being in the situation, it is hard to say. In 4th if I don't go full throttle and say I'm going up hill especially, I can have some stuttering. Basically the system is at the "imperfect" spot for knowing if I want it to blow off or not. I usually know where that is and it doesn't happen unless I'm not paying attention. I'm guessing that wasn't the issue with you though, as it sounds like you were doing a pull.
I don't suppose you had gotten gas somewhere sketchy? Likely not the cause, but just asking. You're probably fine, but maybe take it easy. BTW - you probably don't want to post anything too specific about your pull as it can be generally frowned upon.
Old Dec 26, 2010 | 04:13 AM
raasfaas's Avatar
I hope it's not a problem like this one..
https://www.evolutionm.net/forums/ev...o-failure.html
Old Dec 26, 2010 | 08:58 AM
drocksmash's Avatar
Ok i wont describe the pull next time. I am going to Canada now, so i cant do anything with the car, it will have to sit for a few days.
Car drove fine after that but, never got it back up to speed - I have walbro, TBE, MBC, english tune, intake, LICP. Running 24 pounds on a safe tune.
Gas was fine for the whole tank, but at the end is when i noticed this. The gas light may have been on prior to the pull. If i had a boost leak would my gauge still be accurate?
Well... Ill be back in 3 days and giving you a call dan.
Old Dec 28, 2010 | 12:56 AM
yahu's Avatar
^werd; have fun up North!
If you have a boost leak you would only likely be showing your boost after leak. Let's say the leak is stealing 5psi, then you'd be showing 19psi.
Old Dec 28, 2010 | 10:55 AM
drocksmash's Avatar
pretty sure that it spiking at 24 but i will have to investigate when i get home tomorrow, thanks for the advice
Old Jan 4, 2011 | 06:09 PM
dscevo8's Avatar
you ever figure it out?
Old Jan 6, 2011 | 07:25 AM
drocksmash's Avatar
Pretty convinced that it was just having no gas.... Came back from Canada and she fired right up, have not had a problems since. Havent done any major pulls tho.
Old Jan 6, 2011 | 07:34 AM
4cdndctn's Avatar
Fuel starvation, boost leak or spent plugs... Don't worry unless all 3 check out...
Old Jan 6, 2011 | 08:51 AM
drocksmash's Avatar
I didnt actually check anything, except to see if my boost gauge was still hitting 24 psi, and it was.
I will do some searching to see how to check the spark plugs.
thanks guys
Old Jan 6, 2011 | 09:00 AM
CEY05EVO's Avatar
When I had this issue,it did end it up being the plugs
Old Jan 7, 2011 | 01:13 AM
awdordie's Avatar
It was more than likely low fuel. I've done this before same symptoms same outcome. I have the frogeyes pod on the column which unless u look around it it blocks the gas hand. Went wide open throttle and sure enough it sputtered almost like a fuel cut. My friends 2g eclipse does it as well before the light even comes on. Nothin to worry bout just fill her up and happy boosting. That's my 2 cents.
Widebody_EVO_RS
Mar 31, 2017 11:52 PM
2006GSR
Aug 20, 2016 09:22 PM
Igaly1021
Nov 7, 2015 05:18 PM
car_nut15
10
Oct 7, 2011 07:01 PM
GgreyEVOIX
15
May 1, 2009 02:41 PM
