Evo VIII center differential
Old Jan 16, 2003 | 03:20 PM
wtz's Avatar
wtz
Is it possible to change the 50-50 torque split to 35f-65r by simply changing the planetary gear set? I don't know where one would find different gears, but it seems like this should work.
Cheers,
Old Jan 17, 2003 | 08:39 AM
JaffaKaffafa's Avatar
Are you talking about a permanent 35:65 split or about basing a active, variable set-up around a 35:65 split as a default setting?
Old Jan 17, 2003 | 10:59 AM
chronohunter's Avatar
Re: Evo VIII center differential
Cheers,
It's not very fesiable to try and do it your self (unless you happen to own a very good machine shop ). If you DO have the capability to make one you could sell a bunch!
Cusco does make one for the VII (that will fit) It sells for about $1600 and not only does it change the torque split but it gets rid of the viscous coupler and replaces it with a faster reacting, smoother clutch pack (which is abjustable, locking wise, by changing the preload).
I mentioned on a previous thread that we need to find a source for a group buy
Old Jan 17, 2003 | 11:02 AM
MrAWD's Avatar
Re: Re: Evo VIII center differential
I am still with you on this one!!!
Fedja
Old Jan 17, 2003 | 11:04 AM
BurnOutz's Avatar
We've had so many threads on the center differential. Everytime I log on, I see a new topic about it. Anyways, if you want to have a nice differential, why don't you just wait for the 2004 Evo? I would think they would put ACD on there especially because the STi is coming with DCCD.
Old Jan 17, 2003 | 11:08 AM
Since Europe is getting the same spec (as far as the diffs go) all the U.K. tuner shops will be stocking the 35/65r diff. I wonder if Cusco recognises the demand that will exist for it in a few short months
Old Jan 17, 2003 | 11:16 AM
1. Because I don't want to wait
2. Because I don't want AYC which will probably come with ACD (and the price will probably go up to STi levels)
3. My goal is to build a track worthy VIII (think 80% JUN Hyper Lemon EVO) and Cusco mechanical diffs seem to be the most track worthy as far a balance/ predictabily and price
Oh yea I didn't start this thread...I just cant resist posting on this topic
Old Jan 17, 2003 | 01:22 PM
MrAWD's Avatar
I think you are beyond the on this subject!!
Fedja
Old Jan 17, 2003 | 01:24 PM
MrAWD's Avatar
The thing is that nobody even mentioned ACTIVE differential here just so it wouldn't remind you of the other threads that we have/had on this subject. Until your post...
Fedja
hutch959
Jan 1, 2017 04:45 PM
weeeeeeeeee
May 17, 2016 01:21 PM
Pal215
15
Nov 2, 2015 10:15 AM
GBAILEY472
Jan 31, 2011 10:13 AM
agsmooth84
Lancer Tranny/Drivetrain Tech
Jul 7, 2002 12:26 AM
