overboosting on Evo VII
First hello and sorry for my english, ißm from Switzerland and i have a Evo 7 ..My problem is does....
I drive whitout catalisator and boost 1,45 bar..
When i went back from the accelerator or if i change the gear,the Rpm do not go back for a couple of seconds...
I checkt allready the ECU without faults.
After 3 month now the problem grow bigger.. coz it goes 1000 Rpm higher..
Then i changed the Blow off Valve (HKS) and went to 1,25 Bar pressure down, but the problem allready exists...
Please could you help me
Thanxs Theracer
Guest
Posts: n/a
Sounds like a sticking throttle cable or something. He will grease it and see how that goes. If that doesnt work, I told him to try swapping the ECU from a friend's car onto his to see what happens. Other than that, faulty fuel pump or wrong fuel pressure. let's see what he says.
Guest
Posts: n/a
Originally posted by Guack007
I thought some ecus store car information like odometer
How easy is it to just swap ECU's?
eus_evo8MR
Feb 13, 2013 10:20 AM
