Cam Install Help!!!
Cam Install Help!!!
Does anyone have a link to a cam install or timing belt install guide??? My balancer shaft is off and the shop where the car is wants a writeup on aligning the blance shaft b4 they pull everything apart...
The evomoto guide is nomore! someone help
EDIT: Okay, saw your other post and understand that the cam swap is done but the car is acting up. If the shop only swapped in the cams, they shouldn't have messed with the balance shaft. Anyhow, you definitely need more than internet cam swap directions. You need someone to scan some pages out of the factory service manual for you. It's a big job if they need to pull the timing belt.
the reason they messed with it is because i had a leaking waterpump and i got a new WP, timing belt, balance belt, cams, headstuds...i just got the ALL Data printout from a local shop but it doesnt seem detailed enough...all i need is instructions on lining up the front oil pump/ blance shaft. it seems there must be a trick to it....anyone outthere that can help me out???please
dudical26
73
May 5, 2026 05:15 AM
roni4g63
Jan 31, 2016 04:23 PM
rEVOLUTIONh8
May 14, 2005 12:50 PM
